Other Stuff => Interchangeability => Topic started by: notobikeparkingtax on November 28, 2010, 09:55:06 AM
Title: Brake disc swap CB550F ---> CB750 K7
Post by: notobikeparkingtax on November 28, 2010, 09:55:06 AM
Anyone know if this is a straight swap ? I've sent my K7's disc off to Len Cooper to have a cast iron disc fitted and it's already a week overdue with no sign of it being done. I want to ride my flipping bike!!
 I can get hold of one off a CB550F, part numbers are different but I'm not sure if that means it wouldn't fit at all or that the carrier is painted a different colour!
Thanks in advance,..
Title: Re: Brake disc swap CB550F ---> CB750 K7
Post by: Bryanj on November 28, 2010, 11:04:21 AM
Smaller diameter so it wont work sorry
Post by: notobikeparkingtax on November 28, 2010, 04:17:43 PM
Cheers Bryan, saved me a bit of grief that has !
Post by: Yoshi823 on December 08, 2010, 09:49:15 PM
If you utilised the 550 caliper bracket then you could use the 550 disc.
Post by: notobikeparkingtax on December 12, 2010, 12:06:11 AM
Thanks Yoshi823,, worth knowing.
Having been told by Len Cooper engineering that the brake conversion would be done in 3 weeks, my brake disc should actually be back with me next week...maybe. That'd be nearly 2 months after it was received by them.
Seriously..not a happy bunny right now. If it was going to take two months I'd have appreciated being told that at the beginning.
Post by: Bryanj on December 12, 2010, 09:54:53 AM
Back in the late 70's there was a firm that did cast rotors to bolt onto the standard carrier and i got one for my 500 four, i found that it made no difference in the dry and in the wet the brake worked and locked up sliding the front wheel out from under me!!!
I eventualy went to twin standard discs with one caliper in front and one behind (this was before the 550 came out with mirrir image sliders) plus a Goldwing master, that made the tyre howl when braking but never locked on me
Post by: Yoshi823 on December 12, 2010, 07:16:37 PM
I remember that advert being in 'Bike' magazine & possibly in 'Superbike' mag. It seemed like a good idea at the time, particularly because the brake pads of there day were not that good...until Ferodo brought out a worthwhile compound.
There's a forumite on here that has a CB750K sohc with a 500/550 front disc on it...the 750 is quite a lot bigger & it was this that I noticed.
Post by: matthewmosse on December 12, 2010, 10:49:25 PM
Pfm I think do cast disks to replace stainless on Bmw's so that's where I'd look for cast disks. I deffinately think they have their place if you tend to use the bike in all weathers, though I just drag the front brake on almost pernemently if I get caught in a real downpour on the 500/4, onece warm the standard rotor works fine even in the worst Welsh / Yorkshire downpours, particuarly bearing in mind the tyres get less grip in those conditions and when I onece was on the motorway from Leeds in such conditions visabilit was also down to nil too. Brakes in standard form were still good for hauling a bike, sidecar and spare bike in bits and tools to put spare bike in bits all to a halt at motoway speeds - reduced speeds for conditions as I like to be able to stop on the amount of road I can see!
