SOHC.co.uk Forums => CB500/550 => Topic started by: Grewth on November 27, 2025, 06:55:34 AM
Title: CB550F
Post by: Grewth on November 27, 2025, 06:55:34 AM
I'm considering taking on a 550F project after making the mistake of selling the last one in 1999.
I'm pretty clued up on SOHC 750's now, but I've forgotten most of what I learned about the 550.
So could someone with the requisite wisdom please give me some clues on what's likely to be missing or broken on these bikes.
I seem to remember issues with rear brake drums and fracture prone top yokes (or was that the 500 ?)
Not sure about the above really,  but I'd like to know exactly what I should be looking at when considering a project bike
Title: Re: CB550F
Post by: Sesman on November 27, 2025, 07:10:52 AM
Hi, Gareth.
Which model year? I can only advise on my experience with a 1977 F2, which I sourced from America in complete low mileage condition, minus indicators and seat. Indicator head lamp ears were the biggest headache as they are becoming very rare indeed, along with original seat bases.
Title: Re: CB550F
Post by: Bryanj on November 27, 2025, 08:18:11 AM
Brake drum yes, they can crack, top yoke was 500 and 750.
Ignition switches can be troublesome and there are about 95 different sets of wiring!.
Ocassional gear breakage but not common, cam cover wear is heard of
Title: Re: CB550F
Post by: Grewth on November 27, 2025, 10:24:47 PM
Many thanks,  both of you  !
I think that the pile of bits I'm looking at is a combination of F1 and F2 bits.
Maybe some late 550K, but nothing early.
Brake drums I don't think there is any engineering solution to,  except to keep buying them until you find a good one.
Not heard of a successful re-lining as of yet.
My 550F1 had aftermarket cast alloys, can't remember the make, Italian I think.
Thanks for the heads up about the headlamp mounts - hopefully someone will start making replicas soon.
I think my F1 had a replica seat with a GRP base, and that was 30 years ago.
Ignition switch  ?
Don't  David Silver Spares  sell a decent pattern copy quite cheaply  ?
Title: Re: CB550F
Post by: Bryanj on November 28, 2025, 07:45:48 AM
Yes you can reline the drum, just have to find a man with a lathe
Title: Re: CB550F
Post by: Sesman on November 28, 2025, 08:45:28 AM
Yes, the pattern ignition switches are just fine. Other potential failure points are the RH switchgear starter button, which can turn to goo and disintegrate.
Title: Re: CB550F
Post by: Murf on November 28, 2025, 11:33:28 AM
The 550 I am restoring is a 75 K1 so earlier than the one you are looking at, it was also a very neglected US bike that had probably been sourced from a scrap yard, then badly bodged by its UK PO to get it back on the road.  Luckily I think it had come from a dry climate area so rust has not been a big problem and most of the chrome has survived relatively well and wheels, mudguards, headlight ears are all usable. Looking at the quality of the chrome, which is 50 years old, I am sure we will never see chrome of this quality ever again.
So bad bits:- worn fork stanchions, knackered rocker cover, knackered cam shaft, knackered cam chain tensioner, stretched primary chain (no chain tensioner on these bikes. Leaking oil pump, needs new o rings, most oil seals on engine leaking, complete top end overhaul needed, carb rebuild needed, new wheel bearings and seals, new swinging arm bearings and collar, new brake hoses. New rear brake shoes, repairs to rusted out seat base, new seat cover, repaint frame, battery box and swinging arm, new fuse box, repair and or replacement electrical components. Wrong Speedo and rev counter fitted, check this as good ones are getting harder to find at a reasonable price.
Well  the list just goes on and on and I haven’t opened up the bottom of the engine yet.
Neglected 550s can have a lot of problems however they are nice bikes to work on and I am sort of enjoying doing it, but I would rather be riding it😁.
So if you want a project and fancy a lot of work and spending a lot of money buy a crappy bike. If you want a bike to ride next spring and save some cash buy the best 550 you can find.
Good luck
Title: Re: CB550F
Post by: florence on November 28, 2025, 12:07:12 PM
When I bought my 1974 500/4 in boxes for £150 in 1995, I found the more I stripped the engine, the more problems I found.  Basically, it was worn out, probably from lack of regular oil changes by previous owners.  The camshaft and rockers were scored badly, bores very worn, even the crankshaft was out of tolerance.
Luckily, I managed to find a really excellent low mileage engine from DK Spares for £350.  They actually sent two, the first one I stripped the top end and found it was not in great condition so sent it back.  The second one was found to be excellent though.  I was told it had only done 7K miles.  Being quite particular, and as I had the spares already, I fitted a new cam chain and tensioner, rebored my spare barrel, fitted new pistons and rings and have been running this ever since, changing the oil and filter every 1000 miles.  I am convinced this makes an enormous difference.  It has been a very cheap bike and now the clutch works properly, I love it.  Great fun to ride, even goes round corners reasonably well, although hoping to upgrade the rear shocks soon.
Title: Re: CB550F
Post by: DomP on November 29, 2025, 08:55:07 AM
Ken gave me the number of a bloke in south Wales that can reline brake hubs, i can dig it out unless he pops up with it
Title: Re: CB550F
Post by: Grewth on November 29, 2025, 10:02:26 AM
Thanks for that,  I've obviously been mis-informed.
Title: Re: CB550F
Post by: Grewth on November 29, 2025, 10:13:44 AM
Many thanks also.
Hopefully I'll not be needing that service, but I'll bear it in mind for the future.
Apparently,  the classic Suzuki T500 suffers similar issues, but on the TLS front drum.
I was reading about one  owner who re-lined his front drum ( he was an engineer apparently ), but unfortunately the drum later shattered while he was riding the bike.
Nice !
Maybe he went too far on the interference fit ?
Anyway,  that story sort of put me off the idea of re-lining motorcycle brake drums.
But if someone can successfully re-line the CB550 drum, I'm quite happy to accept that, and I may indeed resort to that solution myself if required.
Title: Re: CB550F
Post by: Murf on November 29, 2025, 11:47:45 AM
If the pile of bits you are looking at is reasonably priced they might be worth a punt but I tend to find people have an inflated idea of what knackered old bikes or boxes of bits are worth. I guess it’s the parts value. However good or restored bikes seem to be reasonably priced, particularly when you consider the high cost of parts and restoring a bike.
Of course there is great satisfaction in taking a pile of bits or a knackered bike and turning them into a nice usable reliable bike that people comment on.  Also if you want to do something a bit different then buying a pile of parts can be the way to go as you aren’t constrained by the guilt originality.
Title: Re: CB550F
Post by: Bryanj on November 29, 2025, 12:14:52 PM
If you buy it i will give you an incomplete bike for scrap value located in Gloucester
Title: Re: CB550F
Post by: Grewth on November 29, 2025, 12:51:46 PM
My technique is usually to keep buying abandoned projects cheaply,  until I have enough good bits to build a complete bike.
I then assemble a big pile of damaged and worn out parts, and sell them on as an abandoned project to some unsuspecting victim.
Seems to be working with my CB750F1 project.
If I come across someone who wants an extortionate price for their sorry looking pile of rusty bits,  I just walk away.
Maybe leaving my phone number before walking.
The sticking point with this abandoned project would seem to be the complete 550F engine which is not in the frame.
Yes,  it's not seized,  but that doesn't mean that it's not completely worn out,  bad head ? bad cam ? bad crank ?
Anyway the present owner seems to think that the engine alone is worth a truckload of money.
The rest of the remaining bits. Less so.
I might just try to persuade him to sell me just the rolling chassis.
Dunno yet.
Title: Re: CB550F
Post by: Grewth on November 29, 2025, 12:59:55 PM
Thanks for the offer !
It might take me a couple of weeks yet to sort out this prospective purchase.
I'm in two minds about it at present.
I'll see what sort of deal I can thrash out with the seller
Title: Re: CB550F
Post by: Otis on November 29, 2025, 04:25:30 PM
I hope that is a comment made in jest!! because I have been the unsuspecting victim on many occasions and I can tell you it's not nice!
Title: Re: CB550F
Post by: Grewth on November 29, 2025, 08:18:30 PM
Truth be told,  I'm actually far too much of a hoarder to actually get organised enough to rip anyone off.
So far I've collected a humongous pile of CB750 bits.
When I finally throw in the towel and retire I'll probably be listing them on ebay and putting up with all the hassle.
My golden rule when shopping used parts on ebay is to never give any seller the benefit of the doubt.
If something is photographed from an obscure angle, it's not unintentional, the seller is trying to hide something.
Certain dealers have developed this into a fine art, but then you've probably already learned that.
This cynical attitude of mine might be a tad negative,  depressing even, but it's served me well over the years.
Title: Re: CB550F
Post by: Laverda Dave on November 30, 2025, 10:56:45 AM
I agree with Otis, having been the victim of a lying toerag on eBay selling absolute junk and posting photos of parts that were nothing like the listing, emmaluck1 is their username and they are still selling on eBay even now. It isn't a nice feeling especially when they said they never received the part back in exchange for my money back even though I sent it back signed for with their signature as proof. eBay didn't want to know despite all the evidence.
Knackered worn out parts deserve to go in the bin and not on eBay for some poor victim to be scammed, how would you feel to receive an expensive worn out and difficult to obtain part for a rebuild. Not everyone has the skill and knowledge to determine from a photo what is worn out and what is serviceable. It is for this reason I now stay away from eBay where I possibly can.
Title: Re: CB550F
Post by: Grewth on November 30, 2025, 03:07:59 PM
Sorry to hear about your misfortune on ebay.
I struggle to beat the rogue sellers, and I've been buying stuff for donkeys years.
I'm not surprised that less experienced folk end up being swindled out of their hard earned cash for worn out junk.
You have to learn to read between the lines of sellers descriptions to reveal the truth.
"Engine turns freely, I haven't heard it run myself , but the previous owner said it was a good runner "
That's dealerspeak for absolutely thrashed to death.
"Condition of inside of tank unknown due to not having the filler flap key"
They've opened it up and it's full of rust and dirt.
"The pictures form part of the description"
That means there is an area of damage somewhere in the photos that isn't obviously apparent.
Usually because they have photographed it from an obscure angle which makes the damage look like a shadow or a reflection.
When you complain to ebay about the item not being as described,  the seller points out that the damage was visible in the photos.
It's a real jungle.
I'd honestly recommend buying stuff at a Jumble instead,  if you can find the time.
Title: Re: CB550F
Post by: DomP on December 03, 2025, 07:34:07 PM
Ebay are terrible to deal with, ive had bad experiences as both a seller and buyer.  It seems if you are prepared to lie you can get away with most things on Ebay because getting problems resolved is made so difficult
