SOHC.co.uk Forums => CB350/400 => Topic started by: element137 on April 21, 2026, 07:29:53 AM
Title: Front Brake Disc - Torque Settings for Bolts
Post by: element137 on April 21, 2026, 07:29:53 AM
Hi everyone , I have had a look at the Haynes manual, but cant see the torque values for the four bolts/nuts that pass through the  front wheel hub and front brake discs, also assume these are thread locked  - as standard , there is no retaining tab washers ? ( as per the rear sprocket nuts )
Title: Re: Front Brake Disc - Torque Settings for Bolts
Post by: McCabe-Thiele (Ted) on April 21, 2026, 08:46:39 AM
Might be worth checking the downloadable Honda workshop manual on this site.
My 400 has lock washers, a paired arrangement iirc.
Post by: exvalvesetdabbler on April 21, 2026, 09:40:48 AM
Try this,
[attachurl=1]
Regards
Dave
Post by: element137 on April 21, 2026, 11:53:52 AM
Thanks - I could not find it in the workshop manual - and I have seen conflicted images reference the lock tab washers - some with - some without ?- not sure if it changed on model years ?
Post by: element137 on April 21, 2026, 11:54:24 AM
Try this,
(Attachment Link)
Regards
Dave
Got it - many thanks for that -
Post by: element137 on April 21, 2026, 11:56:36 AM
Actually looking at that service bulletin, it looks like CB350 had the lock tabs - 400 not fitted ?
Post by: McCabe-Thiele (Ted) on April 21, 2026, 01:10:55 PM
Might be worth checking the 400 parts book.🤔
Post by: taysidedragon on April 21, 2026, 02:43:02 PM
Correct, 400f uses flanged locknuts instead.
Post by: Oddjob on April 21, 2026, 06:04:01 PM
Considering the damage a bolt would do I’d be inclined to fit the tab washers myself or failing that some nyloc nuts
Post by: exvalvesetdabbler on April 21, 2026, 06:51:11 PM
You would need a longer bolt for extra tab washers or for a nyloc to have something to grip
[attachimg=1]
Dave
Post by: Oddjob on April 21, 2026, 07:06:45 PM
Without the washer or flange in this case the existing bolt should be ok.
Post by: TrickyMicky on April 21, 2026, 11:09:54 PM
Whilst I agree that they are not cheap, for such a safety critical part, the genuine flange nuts are available.
Post by: Oddjob on April 21, 2026, 11:22:36 PM
Have they got the serrated flange Mick? If so loads available in stainless steel
Post by: Skoti on April 22, 2026, 07:06:05 AM
Nyloc nuts not really suitable for high temp use such as brake discs, metal lock nuts are more appropriate.
Better safe than sorry.
Post by: TrickyMicky on April 22, 2026, 08:10:43 AM
I'm only going by the pics on the DSS site, which shows them as being smooth, but, listed as genuine parts.
Post by: K2-K6 on April 22, 2026, 08:28:18 AM
The original bolts and flange nuts are fine, with no attendant risk as the design and tensile load specifically copes with this application.
Putting a flanged nut, with no washer is the anti-shake method chosen in place of using lock tabs.
They are held by the bolt being torqued correctly to keep it in tension competently.
You'd not want to swap them for stainless, without knowing details about both material specifications.
Post by: K2-K6 on April 22, 2026, 08:42:22 AM
These type application are usually assembled dry, just the zinc coating on the components and nothing else as part of their function.
Post by: Mikep328 on April 22, 2026, 09:42:47 AM
"They are held by the bolt being torqued correctly to keep it in tension competently.
You'd not want to swap them for stainless, without knowing details about both material specifications."
Yep...An item that is often ignored with fastener "upgrades," is the "self locking" function of properly torqued fittings.  For example, if an OEM fitting uses a grade 2 bolt/nut and someone replaces it with a grade 8 bolt/nut because "it's better," the result will be a fastener that is very prone to loosening because the torque setting in the service manual to properly stretch that Grade 2 bolt will be far too low for the grade 8.  ;)
Post by: Skoti on April 22, 2026, 11:21:27 AM
Absolutely agree,
and the same applies to stainless fasteners especially on safety critical areas such as steering, suspension and brakes.
Had to remove some stainless engine mounting fasteners on my Norton and replace with OEM stuff as they were frequently needing retightened.
Been fine ever since.
Be sure, be safe.
Post by: element137 on April 22, 2026, 12:48:13 PM
The OEM nuts are smooth flanged - I did look at using some alternative Stainless Nuts - but they are shallower than the OEM nuts , i.e., the height above the flange to the top of the nut is much higher on OEM ,so less thread would be have been engaged so decided to clean up the OEM bolts and nuts and intend to re-use them - I was curious about the conflicting info about locking tabs or not , and I couldn't find the torque setting anywhere (until it was kindly posted in this thread ( many thanks for that ) -
Post by: element137 on April 22, 2026, 12:48:37 PM
No thread lock ?
Post by: exvalvesetdabbler on April 22, 2026, 01:05:55 PM
They would normally have been  nipped up clean and dry.  If you put thread lock or lube on them it  will give you a greater pre load for the same torque setting.  I normally knock  30 % of the torque to compensate if using thread lock or anti seize. Just my rule of thumb, others may have different ideas.
It's the torque and the friction of the flat flange face  that keeps them done up.
Regards
Dave
Post by: K2-K6 on April 22, 2026, 01:07:24 PM
No thread lock ?
If the manual doesn't specify it, then not necessary to use.
In all practical sense, its not going to make much difference if used, but has the potential to give misreading on torque as it's more "lubricant" than dry only.
What's not immediately clear in design like this is that it effectively locks itself by the bolt threads by  elongation under tensile load, but the nut threads are under compressive load when the flange touches and torque applied. The opposing change in thread pitch between the two making a "lock" nut from that action.
The flange effectively gripping the flat surface under tensile elasticity of the bolt prevents backing out too.
Post by: Oddjob on April 22, 2026, 02:50:40 PM
That is a point Skoti. I’ve never found the hub carrier to get that hot, even when I was racing the 500, not hot enough to melt the insert anyway but fair point, maybe met locks would be a better choice.
Without the serrations gripping the disc you’re relying on just the torque keeping it in place, not a good idea imo, I’ve had one come out undone, lost the nut entirely. If the bolt had started to come out I could have been in serious trouble but luckily it stayed in place.
Post by: element137 on April 22, 2026, 02:53:41 PM
Thanks all for the very informative replies - I trust Honda's engineering ( even if in this case its 50 years old ) so will go with dry fit and correct torque - really appreciate all the input -
Post by: TrickyMicky on April 22, 2026, 07:11:14 PM
  Did you ever wonder as to why only one?
Post by: Oddjob on April 22, 2026, 08:24:15 PM
It was actually 2☹️ I lent the bike to my BIL and didn’t really inspect it when he returned it. A few months later I went to polish it and noticed the missing nut, what was worse was one of the bolts was missing entirely, my BIL hadn’t bothered to mention it so it either fell out whilst in motion or most likely it fell out when parked on the sidestand. The nuts were the flanged Honda ones off a GL1100 as I was running 2 discs. They were all torqued to spec with a Snap On torque wrench. Why 2 came undone is a mystery.
I’ve got my suspicions that it may have been my BIL nicking bits. It came back with tools missing from a brand new toolkit, including the plug spanner. Lots of other bits seemed to have gone as well, just small pieces that are easy to miss until you either want them or spot them missing when you’re cleaning the bike.
Post by: exvalvesetdabbler on April 22, 2026, 08:56:45 PM
Maybe he's building a bike a piece at a time by nicking bits of yours😀
Post by: Oddjob on April 22, 2026, 09:29:25 PM
He actually has my K reg 500. He’s had it now about 10 years, he claims I gave it him, which I deny. It’s not worth the aggro tbh, he keeps it on the road and serviced so that’s something but he’s always been jealous of my L reg 500.
Post by: element137 on April 23, 2026, 07:56:02 AM
Johnny Cash wrote that plan in the song 'One piece at a Time '  ;)
