Other Stuff => Desperately Seeking!! => Topic started by: Kev Bishop on May 03, 2026, 03:49:05 PM
Hi looking for a bearing tube if that’s what you call it for a 750 SOHC wear on the Bering surface not a problem as I’m using taper bearings and will be cutting it down and using it for a spacer . UK preferably
Cheers Kev
The taper roller bearing conversion uses a different collar than the standard one. Not sure you can adapt it tbh. It may be possible with a lathe I suppose.
