SOHC.co.uk Forums => CB500/550 => Topic started by: gaz172 on May 11, 2026, 08:26:53 PM
I've found a split in my air box to carb rubber, i was wanting to replace it but it seems nowhere sells them, has anybody any idea where i could get a replacement,or an alternative that fits ? thanks
Do you mean carb to head or airbox to carb
airbox to carb
I’ve got a couple off 500, used but ok… I think the same ...you can have if you like :o)
550 has different rubbers to 500, there was a member on the US forum that was making the 550 rubbers otherwise they only come with the plenum chamber if its available
Sorry 550 K3 is different as it has PD carbs
I should clarify Bryans comments. It’s only the 550K3 which has different intake rubbers than the 500, the 550F has the same as the 500. It’s due to the different carbs fitted to the K3, which were PD carbs. The 500 and 550F share essentially the same carbs.
Which one is split? 2/3 availble here: https://honda4parts.nl/product_info.php?products_id=1975&language=en
unfortuntely its number 1
Thats the usual one that splits
You need 17310404670 but it is discontinued and over £100
There are sets available at CB-Four.com just found them, supposedly in stock.
Thats them (hopefully). got them ordered anyway, thanks for the help.
You’re welcome Gaz, I’m pretty good at finding stuff others struggle to find.
