SOHC.co.uk Forums => CB500/550 => Topic started by: Neilw on May 31, 2026, 09:30:35 PM
I need to replace the rear light, as the housing is bent out of shape, and the lens doesn't fit correctly.
I've been trying to find an original housing, which I can see is a Stanley HM-11RC. The lens I have is a Stanley HM-15RC, which I can reuse
Should the two be the same, i.e. match, or can they be different?
I'm a bit confused what I should get - any help appreciated.
I've found that the HM-11RC is for older bikes, and the correct period part is the HM-15RC. Looks like I have a Frankenstein, correct lens, incorrect body.
I have located a reproduction part which will fit. Interesting that David Silvers is selling new, the HM-111RC for this model bike, which will fit, but is not the correct period.
The correct one for a UK version of the 550f2 is the smaller of the 2 fittings, has 2 screws attaching the lens. The K3 though got the much bigger one with 4 screws attaching the lens.
I seem to recall there was also a spacing difference between the mounting bolts so maybe you have the wrong rear light bracket as well.
I have the UK bracket (according to CMSL and parts lists). I think i have the incorrect light body, with the correct lens fitted to it. It's all good though, a replacement part is on its way - i was hoping to re-use the original lens, guess that will be for Ebay now!
The early lens wont fit the later body as its only half the size
