SOHC.co.uk Forums => CB750 => Topic started by: nealmax on November 19, 2005, 03:44:25 PM
Title: 750 specialist
Post by: nealmax on November 19, 2005, 03:44:25 PM
Is there anyone out there that specializes in 750 engines , spares, rebuilds, etc
Title: Re:750 specialist
Post by: SteveD CB500K0 on November 19, 2005, 06:22:18 PM
Do you want to do it yourself?
If so there are some excellent places to buy parts right here in the UK. The best is probably www.davidsilverspares.co.uk but there are others (and one or two in Holland/Germany.  You can get help and advice from here or from www.sohc4.net
If you are looking for a restoration shop to do the job for you, check out Classic & Motorcycle Mechanics.
I'm assuming from your email address that you are in the UK??
Post by: JonnyB on November 19, 2005, 06:33:50 PM
I'm with Steve, the SOHC engine is not really that complicated, and with the aid of a manual such as Haynes or Clymer, you can achieve a lot. and there is a lot of satisfaction (as well as frustration) to doing it yourself.
Post by: jimshea on November 20, 2005, 11:28:42 AM
nealmax,
What needs to be done? Where are you located?
Cheers,
Jim.
