SOHC.co.uk Forums => CB750 => Topic started by: redtractor on August 04, 2026, 05:16:09 PM
Title: Pamco ignition
Post by: redtractor on August 04, 2026, 05:16:09 PM
Hi, Does anyone know if Dyna coils will work with Pamco ignition, thanks, Sarah.
Title: Re: Pamco ignition
Post by: McCabe-Thiele (Ted) on August 04, 2026, 06:18:57 PM
Do you know the specification of your coils (Impedance/resistance) rather than the brand.
As electronic ignition is meant to take the place of points that should work with most coils if it's for a 750 I would have thought you just need the right resistance Dyna coil.
Post by: Skoti on August 04, 2026, 08:02:40 PM
If Dyna coils are OK to replace stock coils then they will be fine.
https://www.dynaonline.com/dyna-igntion-coils-set-dual-output-3ohm-dual-plug-single-fire-1/?srsltid=AfmBOoqNZzKdbwfoz73FRCf8FNFe5GDMFQW3IYmO9cuVA7DeWtOtjUHg (https://www.dynaonline.com/dyna-igntion-coils-set-dual-output-3ohm-dual-plug-single-fire-1/?srsltid=AfmBOoqNZzKdbwfoz73FRCf8FNFe5GDMFQW3IYmO9cuVA7DeWtOtjUHg)
https://4into1.com/pamco-instructions-honda-cb350f-cb400f-cb500k-cb550-cb750/?srsltid=AfmBOopBt_ch93BkgbGIlCxfRx-xPxtuDNTFi22yQevAKXVUlJIeIsWj (https://4into1.com/pamco-instructions-honda-cb350f-cb400f-cb500k-cb550-cb750/?srsltid=AfmBOopBt_ch93BkgbGIlCxfRx-xPxtuDNTFi22yQevAKXVUlJIeIsWj)
Technical Information:
Technology: Hall effect sensor, IGBT coil driver
Dwell: Fixed, 120 degrees
Coil primary resistance: 2.5 to 4.5 Ohms, dual output. (Stock coils may be re-used)
Operating voltage: 6 to 18 VDC
Operating current: 13 ma
Operating Temperature: -40 to +150C (-40 to 302F)
Spark Advance: Standard, centrifugal
Simple installation: Battery, ground and coils. No external box of tricks.
Plate milled from high quality aluminum.
Rotor with two magnets made from a solid billet of aluminum on a CNC machine.
Post by: redtractor on August 08, 2026, 07:57:03 PM
Sounds like they will work, thanks Guys
Post by: McCabe-Thiele (Ted) on August 08, 2026, 08:46:45 PM
Iirc Dyna Coils have the resistance moulded into the casing.
