SOHC.co.uk Forums => CB500/550 => Topic started by: bbrian66 on August 16, 2026, 03:54:40 PM
Hi Guys
Does anyone know where I can find the wire spring clip that holds the tank filler flap down? I can't find one anywhere so don't know if I'm looking in the wrong place, or wether they're just not available.
If not available, does anyone have suggestions as to what i can do?
Thanks!
Make one. You just need the right type of wire.
Yes that did seem to be an option. Do you happen to know the dia of the wire i'd need?
I’d say 1 or 1.5mm should do it. About the thickness of a spark plug helicoil if you have one. Might be able to unwind one of those, shape it and then anneal it to keep its shape.
I could measure the thickness of one of mine for you but I'd guess 1-1.2mm
Thanks DomP - I've bought a couple of short lengths of 1.0mm and 1.5mm from fleabay - I'll see what I make of these when they turn up.
