SOHC.co.uk Forums => Project Board => Topic started by: Rob Baker on October 05, 2026, 02:54:01 PM
Hi
I have a 1992 400/4 that is in need of a full restoration it has spend several years under a tarp in a garden & therefore is in poor condition.
Its has 11,400 miles on the clock I believe the engine starts & runs.
I was planning of restoring it myself but due to health issues this is no longer possible so it needs a new home & someone to take on the restoration this classic deserves.
If anyone is interested please contact me either on here or by email rob.baker1050@gmail.com.
Regards
Rob.
Welcome to the forum Rob.
The Honda CB400/4 goes from 1974-1977, is this the model you are referring to or is it a USA import that came into the UK and registered at DVLA in 1992?
As Julie says it cant be a 1992 model, if it is a us import there will be a vin plate giving year of make OR if it is 1992 the vin plate will give a model number, eithe way with the information we can help better.
As a new member you need more posts before you can put pictures in a post.
It could always be a 92 Super Four which is a dohc of course
Hi There
Thanks for the information regarding the age of the bike I did think 1992 seemed a bit young for this bike.
I have a feeling that it may have been imported from Canada ?.
You said there should be a vin plate on the bike ? is this going to be on the frame around the head stock area ?.
I'll have a look & report back.
Cheers Rob
Early ones on headstock RH side, later may be on downtube in front of engine or by rh sidepanel
Hi Rob
Why not introduce yourself on the New Members Forum here, and you'll soon have the five posts you need to post some pics of this bike. ;)
Found the vin plate details as follows ....
CB400F Sn 1006758
Year of manafacture is Oct 1974
Welcome Rob.
It sounds like the F model with the pillion footrests mounted directly onto the swing arm.
Does it have a plain yellow fuel tank with black side panels?
Thats a fairly early one, from Canada may have a Km speedo, just about everything else is same as UK one, may have dual filament front indicators as running lights, not legal in UK but you just disconnect 2 wires
The model is a blue CB400F super Sport 1974 & was imported from the USA in 1990.
I just need to find it a new home now.
