SOHC.co.uk Forums => CB750 => Topic started by: UK Pete on March 08, 2011, 07:22:43 AM
Does any one know if K1 oistons and rings work in a F1, if so are there any advantages or dissadvantages,
Pete
::) off the top of my head i would say they would work,as long as they are the same size, a local engineer who has done work for me would always bore the barrels too match the pistons and not just bore too a specified oversize ,i have mixed and matched k0- k4 bits over the years, i think the only real difference was in the f2 with the bigger chocolate valves, I'm sure some one will put you right soon enough
Not 100% sure but i think you will get a slightly lower compression ratio
I cant remember Pete if the F1 had domed pistons the same as the F2, if it did then + one with the slightly lower compression...but it really would be very slightly lower....
The F1 pistons are not as domed as the F2, they are very slightly domed with small cut aways, here's a pic of mine.
(http://i192.photobucket.com/albums/z244/DennisMcc/Engine/Rebuild-15.jpg)
Den
There was a change somewhere in the production run of the F1 from flat to domed pistons. I have both types here but they are both stamped '392'. Some Ebay **** sold me barrels and pistons, supposed to be K1 but were F1 before I attended the ChrisR school of CB750 part identification. Shame as they have only done 20K.
cheers
Ash
Hi ash if you are considering selling give me a pm with details as i still do not have a top end for my cafe project
Pete
Hi Pete
Can you send me a blank text so that I have your number and I will call you re: barrels and pistons
07515121226
Ash
