General => New Member Introductions => Topic started by: ST1100 on April 27, 2011, 01:10:31 PM
Title: Reporting as ordered...
Post by: ST1100 on April 27, 2011, 01:10:31 PM
G'Day,
started an introduction at http://forums.sohc4.net/index.php?topic=87935.0 (http://forums.sohc4.net/index.php?topic=87935.0) and got loured by SteveD  ;)
Bought two CB500/4s recently and will start refurb/rebuild in a couple of weeks, gonna be on a parts-chase then...
Also unclear yet what colour sheme the EC spec bikes (if there has been such back then) did have
Previews of the mess I trew my money on  ;)
(http://www.my-mc.com/messages/13427/146162.jpg)
(http://www.my-mc.com/messages/13427/146163.jpg)
(no, them boats where not included...)
Title: Re: Reporting as ordered...
Post by: Bryanj on April 27, 2011, 05:22:26 PM
EC colours were same as everywhere else, PM me the frame numbers and i will give you an aproximate build date plus choice of colours
Post by: K2-K6 on April 27, 2011, 06:24:31 PM
Hello and welcome to the forum.
They'll keep you busy for a while but look to be mostly there. Curious disc arrangement you seem to have a twin disc setup but spread across two bikes that I've not seen before.
Also the one with the fairing appears to have a Yoshimura pattern to the downpipes that may be period mods.
Post by: Spitfire on April 27, 2011, 07:00:20 PM
Welcome to the forums, they certainly look ripe for a little TLC, have fun.
Den
Post by: UK Pete on April 27, 2011, 08:46:08 PM
Hi and welcome, are you restoring to standard or making something special?
Pete
Post by: ST1100 on April 27, 2011, 10:52:42 PM
Hi and thanx!
the one w/out fairing and the 4x4 is a '76 I plan to refurb to OEM condition, and sell to a caring owner...
Besides the 'rippled' ignition- and clutch-covers it has those aluminum-bed rims with 'collars'
Dunno yet if I should leave the 'M-style' bar on it, I tend to get the OEM touring handlebar for it.
Frame No. 2083333
Engine No. 2169911
(seems to be a K1 frame with a K2 engine then?)
It also has the fork-bottoms for fixing two caliper/arms, which I'd like to nick off and rebuild it to OEM LHS single disk.
The red tank on it is finished... like a noodle filter... you can brake through with your fingernails... was stored bone dry...
But its the blue tank on the other one that belongs to it anyway, which is in good shape so far (will see once we get the numberless layers of paint off...)
The one with this Tomaselli(??) bikini-fairing (that thing is tucked on with HILTI band...  ::) ) is a '73 and has a 'special title' issued '78 by the dept of automotive and transportation, 'legalizing' the Marving 4-1, intake bellmouths (no filters or mesh... now that's gonna be fun with them cops...  ;D ), rear-sets and clip-on handles. (is also has a shorter(!) swing-arm from a post '85 CB installed... ??? )
That one is a keeper (for that title allone) I plan to 'cafe', would like to get a shiny aluminum tank (not narrowed as I already knock my shins on the valve covers and carbs...) and tail-cone, flat upper tripple-clamp, place the instruments lower and more horizontal (K0 clocks with the embedded idiot lights would be great...), get dual disks on it (probably need to swap the (shorter?) hub and speedo drive from the '76 as well), etc...
Frame No. 2016197
Engine No. 2016202
seems to be a true K1 then
Those are the b/w pics stapled into its 'special title':
(http://www.my-mc.com/messages/13427/146178.jpg)
(http://www.my-mc.com/messages/13427/146179.jpg)
Technically I will have to stay close to this to pass the MOT, seat and tank are not soo critical there, but I'll have to see if I get away with the twin-disk setup then (I think a CX500 MC & lever should match nicely with the CB's clutch lever)
Engines on both look dry and rotating (pumping the kick by hand), will check compression and visuals of exhaust ports to determine of both require rebuild.
Wirings are the usual mess, electrical tape, etc... plant to equip both with electronic ignition however.
Lots of work, lots to be organized, lots of 'fancy language' gonna be used, frames to be sanded and repainted, but I think the whole project is going to be lots of fun.
Haven't started yet, as I'm currently re-furbing a '94 ST1100 with >190.000km on the clock (technically +A but got vandalized, kicked over, etc... dumbasses...  :( ),
but already stretching out on parts sources, ideas and tips  8)
Post by: Bryanj on April 28, 2011, 06:33:47 AM
2016197 SHOULD have been built about March 72 the 76 is still a K1 even though the frame number is high as Honda were building K2 for the US; 550 K0 for the US and K1 for europe and UK all at the same time!!
Post by: ST1100 on April 28, 2011, 06:51:04 AM
Thanx Bryanj,
the docs only show the date the vehicle received its first registration, not how long it was on stock at the importer.
Any objections on removing the dual disk fork-bottoms from the '76 to use them on the 'cafe'?
I don't think that model/year ever came with dual disks and also the dimensional drawing inside the title (which is a little booklet) shows only one at LHS.
Any other do's and don'ts to observe?
Any hints are highly welcomed, before we start to work into a wrong direction and have to tear down anything.
Post by: Bryanj on April 28, 2011, 05:03:47 PM
They are probably from a 550 so no problem at all with the swop as long as you keep all the internals with the steel legs due to variations
Post by: ST1100 on April 28, 2011, 08:01:21 PM
Certainly will swap the complete fork legs and check everything bit by bit during the rebuild/overhaul, who knows how they have been messed with over the generations...  ???
W/shop manuals (both, 500 and 550) are already downloaded and get studdied carefully...
When even on a '94 ST, which was serviced regularly at a workshop(!), bolts have been mixed, replaced with 'any' style, or rounded off, will there be no end to the WTF about incompetent tinkering on them CBs... (already spotted slotted bolts holding the valve covers and such...  ::)
I'm already prepared to find things like electrical tape or plastic plumbing pipes inside them forks...  :o
But I think everyone around here probably went though such findings during his rebuilds...
Post by: ST1100 on October 27, 2015, 07:05:52 PM
G'Day again...
And apologizes for going mute...  :-[
After 3 years a friend and I f i n a l l y managed to find a small, affordable workshop space...  :o
Currently busy collecting all our stuff from various locations and hauling it into the new burrow...
Will take some time and work till fully operational, but I do have a permanent home for the vintage SOHC bikes now...
cheers!
Post by: SteveD CB500K0 on October 27, 2015, 07:18:29 PM
Is this a record?
Welcome back.
Start a project thread as we now have a special area for these.
Steve
Post by: ST1100 on November 08, 2015, 07:20:46 PM
Is this a record?
LOL! Probably...  ;D
Anyway, the FOB is operational!  8)
First official tasks:
- replaced rear wheel bearings and seal on my '00 ST1100 (as seen in avatar)
- helped my friend/co-tenant to revive his '79 Z750
(http://motorbike-search-engine.co.uk/classic-bikes-2/1979-Z750.jpg)
After 15 years grounding it suffers issues like seized callipers and such...
Once that's a roller with MOT I'll start knocking the CB500/4s apart... and be annoying with all sorts of questions in a dedicated build/project thread  ;D
Post by: JamesH on November 08, 2015, 08:53:01 PM
Cool. Speak to you in 2019 then :-)...
Post by: ST1100 on November 10, 2015, 08:08:07 PM
LOL!  ;D
No, I seriously hope to have a continuous attachment to them two bikes now...
And, having that workshop space now is really great!  8)
Post by: JamesH on November 10, 2015, 10:34:52 PM
:-) glad to hear it...
Post by: ST1100 on November 15, 2015, 05:21:20 PM
Yeah... its getting serious now...  ;)
The place is getting together, the shelves are still a mess, after moving a lot to clean up and sort... friend's z750 under surgery...
[attach=1]
great to have some store space avail...
[attach=2]
vice and column drill...
[attach=3]
the two "shipwrecks" are a sore sight for sure... but finally have found a dry and clean refuge...
[attach=4]
the yellow frame in the background is a 3rd CB5/4 (well, like 50% of one), with a usable front-end, wheels, engine, etc... but everything else pretty much missing...
Post by: ST1100 on November 15, 2020, 02:00:44 PM
uh-boy... its 2020 already...  ???
Lots had happened, but not to my CB500's though... hope to FINALLY get on them this winter...
Shed has been relocated though... 73m²... spacious man-cave  ;D
[attach=1]
And I finally got myself a tire mounting machine...  8)
(mulling over it since 3 years, but at 4 people with 7 running & 3 project bikes...)
Any objections using such a device on the SOHC spoke wheels?
Post by: Bryanj on November 15, 2020, 02:43:31 PM
Jealous!!!
Post by: McCabe-Thiele (Ted) on November 15, 2020, 10:20:44 PM
Nice looking workshop you have there ST1100 I see you are in living in Wein - Osterreich.
I was born in Klagenfurt in 1948 I came to the UK with my Mother Paula when I was 5 years of age. My brother & I still have family who live in Klagenfurt - I have only returned twice to my homeland once in 2003 and again in 2014 to take my mothers ashes to the Church where she was Baptised in Maria Rain.
It's a beautiful country - but wow is it expensive as a tourist I guess Honda bike parts are expensive as well - sorry if I have hijacked this post  a tad.
(https://live.staticflickr.com/65535/50607031651_be0f3aca28_k.jpg) (https://flic.kr/p/2k6Ygot)Klagenfurt (https://flic.kr/p/2k6Ygot) by Teddy Bagshaw (https://www.flickr.com/photos/186528626@N08/), on Flickr
..A little history about the dragon statue.  https://www.little-dragon.se/the-dragon-statue-in-klagenfurt/
Post by: taysidedragon on November 15, 2020, 11:53:10 PM
Nice dragon! 🏴󠁧󠁢󠁷󠁬󠁳󠁿👍
Post by: ST1100 on November 16, 2020, 06:29:41 PM
Lots (too much) was going on...
Besides keeping on top of the daily runners I refurbed a CX500 Eurosport, which alone took >1 year...
Interesting job, runs very smooth again, fully roadworthy, owner is quite happy though...  8)
Bought and fixed up a '96 ST1100, also running perfectagain, sold to a friend now...
GF's Kawasaki ER-5 needed attention, in January I got her an NT700VA (which she seems to like, won't stop riding that thing  ;D)
This winter one of the CB500 get's it...  ;)
Post by: Andrew-S on November 16, 2020, 06:38:22 PM
Good luck with your two CB500/4 rebuilds and also the recommissioning your mate's Z750E - a stonking bike, I loved mine back in the early 80's and it's a rare Zed these days. In fact, it I threw it down the road wearing a t-shirt and jeans, not recommended!  :-[  Here it is after I'd fixed it up with new paintwork from Dream Machine.
Cheers, Andrew
Post by: ST1100 on November 16, 2020, 08:47:52 PM
...recommissioning your mate's Z750E...
Engine is in parts on the bench...  ;)
He got heads, guides and seats made, new pistons are here, hunted down pipes/collector and silencers for over a year, dunno when he intends to continue... parts are hard to get for those bikes, Kawa mixing from various series/models doesn't ease things...
he's still chasing a wiring harness as the one in the bike is crumbling...
Post by: McCabe-Thiele (Ted) on November 16, 2020, 11:07:12 PM
It's a shame the Lindworm skeleton  turned out to be the head of a woolly rhinoceros.
