SOHC.co.uk Forums => CB500/550 => Topic started by: kendo57 on June 26, 2011, 09:06:20 PM
Title: front mudguard mounting 550f2
Post by: kendo57 on June 26, 2011, 09:06:20 PM
Can someone tell me if the left mudguard mount fits behined the brake swivel bracket
or bolts to the top of it.
Looking at pictures in my old manual [cb500] it looks to bolt between the forkleg and
brake bracket but i am sure on mine it was bolted to the outside of the bracket.
Title: Re: front mudguard mounting 550f2
Post by: florence on June 27, 2011, 09:08:49 AM
It should be behind, i.e, next to the fork leg, then bracket on top of it.
Post by: kendo57 on June 27, 2011, 11:07:43 AM
Thanks, it looks like the previous owner has bent the bracket and fitted to the outside.
Post by: SteveD CB500K0 on June 27, 2011, 02:35:11 PM
I've just checked on mine and Steve (Florence) is correct.
If yours is the other way round the movement of the front brake caliper must be compromised (?)
Post by: florence on June 28, 2011, 11:09:52 AM
Oh my golly gosh, I've just looked at mine and you are correct.  The mudguard is on the outside.  Humble apologies :-[
Post by: kendo57 on June 28, 2011, 10:43:38 PM
Well the way the bracket is  shaped it looks like it should go on the outside and
i have found a picture in the CB500 manual showing it on the outside.
So i think Oddjob has now convinced me the outside is the way to go.
Thanks again.
