SOHC.co.uk Forums => CB500/550 => Topic started by: andy_c101 on May 27, 2012, 11:00:06 PM
Title: cylinderhead overhaul
Post by: andy_c101 on May 27, 2012, 11:00:06 PM
[continuing on from my December thread....... I know I'm a but slow at this game]
[http://www.sohc.co.uk/index.php/topic,4090.0.html]
I did decide to 'live with my slight oil weep' from the head gasket for a while, but now the old girl has taken up smokin'!
Compression test seemed good (?) at around 150-170psi; so I'm thinking it's probably valve stem seals.
& for all I know they may well be 35 years old!
So having followed the 'if it aint broke dont fix it school', it's now broke, so i need to fix it!
This means off with the head, to do valve seals and the gasket/oilways; & generally check it over.
- at least I'm a dab hand at removing carbs (down to 30 minutes after several years of training!); the pipes are off (me thinks I may need to do something with those down pipes too... probably throw money at them).
-rocker cover off, but one of the two camchain sprocket bolts is seized on solid, and the flats are now rounded. Doh! >:(
 I think I'll have to invest in a set of "Irwins bolt removers".
http://www.screwfix.com/p/irwin-5-piece-bolt-grip-nut-remover-set/96028?cm_mmc=GoogleBase-_-Datafeed-_-Automotive-_-Irwin%205%20Piece%20Bolt%20Grip%20Nut%20Remover%20Set
- any tried those?
I let you all know how I get on....
Title: Re: cylinderhead overhaul
Post by: hairygit on May 28, 2012, 09:38:20 AM
I recall helping a mate do a rebuild on a 550 many years ago, and the camchain was fitted with a spring link, which means you can split the chain and remove the head without romving the cam sprocket. As far as I know a split camchain was standard, as the motor had not been apart from new (all the yellow paint was still intact on the rocker bolts etc) but for a definite answer, Brian J is the man who'll know for sure! ;D
Post by: andy_c101 on May 28, 2012, 11:28:15 PM
I resorted to using an "Irwins bolt remover" socket on the camchain sprocket fixing bolt.
It has chewed the bolt head, so it will need replacing for the rebuild;
but the Irwin tool worked a treat.
The next snag I found is with nut/bolts numbers 2,3,&5 (the inner ones that have the rubber sealing cap) and are buried deep inside the narrow access hole in the head casting - (photo).
first my 12mm A/F standard 1/2" sq drive socket o/dia is too large to go down the access hole;
so using my (cheap) small 3/8 sq drive socket, the heads of these nuts rounded off!
- this despite soaking for half a day with 3-in-1 penetrating oil, (& then after the first difficult nut) using the hot air heat gun.
- ahah! I have my Irwins sockets!.....but...... they have a 3/8 sq drive and whacking-greater Hex-A/F; the hex prevents it going deep enough down the bolt hole.
- only one option..... file the flats off the Irwin socket, down to approx 18mm o/dia! (photo - & that was onlyhalf way).
-  eventually the Irwin socket did the trick, three times over it worked.
I shouldn't  be surprised, this is often the challenge (with 30yr+ old bikes) dealing with those siezed/sheared fasteners.
next task is to lift the head ..... and see what lurks inside.....
( I didn't have time tonight, and didnt want to rush that)
Post by: Bryanj on May 29, 2012, 07:17:02 AM
Use only 6 sided sockets when doing the head bolts, if you can find a supplier there is a whitworth socket that is a "Hammer on" fit on a 12 mm hexagon (3/16 or 1/4 but cant remember which!) as to the spring link on the cam chain that was NEVER a fitment from Honda on any of the fours but the 450/500 twin SOFT link is a fit if you want to change the camchain without splitting the crankcases, speaking of which if you do split the crankcases a new primary chain is a must even tho' its expensive.
Post by: andy_c101 on May 29, 2012, 10:57:58 PM
The head is off.
My attention first was directed to 4th cylinder, exhaust valve/seal.
I could see into No4 Ex/port, and the port had a trail of oil from the lower valve stem.
Next I removed No4 Ex valve springs, then eased off the valve stem seal.
The stem seal lip has a 'nick' on the lip (at about 10 o'clock in the photo)
but then on wiping away the oil remnants, I see the top of the valve GUIDE is cracked! (3 o'clock & 6 o'clock, in the photo)
No wonder she was burning oil on No4.
- need to take a close look at all the valve guides now.......
Has any one else come across this type of valve guide failure before?
Post by: Bryanj on May 30, 2012, 09:36:27 PM
Cracked guide is usualy due to valve stem getting bent when re-assembling the rocker cover to head and not reading the book!!
Post by: andy_c101 on May 30, 2012, 11:20:27 PM
Bryan,
yes I see what you mean (- & I have found the specific note in the manuals about tappet alignent on rebuild).
I'm finding a few little signs that 'someone has been here before'!
actually that particular valve does not want to fall cleanly through the guide (suggest one or both are not 'true'; it also looks 'newer' than others (ie less carbon buildup on it)
- one cylinder stud is definitely newer (shinier) than others;
- some of the rocker cover bolts are black-bolt capscrews (unusual for Honda?)
- and a couple of 'dinks' on the rocker gasket faces, indicates carelessness by someone in the past.
I guess that's often the case with an old bike with big gaps in its history.
Title: Re: cylinderhead overhaul...continues
Post by: andy_c101 on June 06, 2012, 09:08:06 PM
continuing the tear-down....
it just got expensive!
I find 7 out of 8 valve guides have hairine cracks, and the valve stems have a tight spot too! (indicating a slight bend inthe stem; sure enough once removed the bent stems were confirmed.
BryanJ was right, someone (previous owner/monkey!) has fouled the rocker arm and valve stems on assembly; there's even a slight 'dink' one on the top edge of the valve stem.
- anyone ever heard of this so bad before?
So its new valves & guides required; but No4 Ex/valve (the worst offender) has obviously been putting high contact load on the rocker/cam lobe, that cam lobe is now right on bottom limit.  >:(
I guess my best bet is David Silvers or CMSNL for parts?
Q1: Anyone know where I can obtain the 5.5mm guide driver tool?
Q2: When i get new valves & guides, I DONT have to ream the new guides do I?
Q3: Can I just lap the valve seats into the head or do they need 'properly re-cutting'? If so any suggestions for cutting tools?
Q4: if anyone has a half decent camshaft.... ??
On the plus side the cylinder bores look good & measure up A-OK, as do piston ring fit/clearances.
At least I found the problem...
i better start saving the pennies.
Post by: UK Pete on June 06, 2012, 09:16:18 PM
Hi Andy have a read of this  http://www.sohc.co.uk/index.php/topic,4330.msg19487.html#msg19487
pete
Post by: Bryanj on June 07, 2012, 06:15:24 AM
The drift is easy to make; yes you DO have to ream the new guides; yes you DO have to cut the seats. Put some pictures up of the cam and relevant follower to let us see how bad they are.
And your cheapest repair is a used complete head, dont forget all the 500 and 550 SOHC fours use the same head
Post by: andy_c101 on June 07, 2012, 09:13:55 PM
Firstly to Pete:
Looks like you did a great job on yours 750(?) head.
Where did you buy the cutter?
For BryanJ:
some photos of the camshaft, No4 Ex valve lobe.
To the outside edge of the lobe is an unworn ridge; I tried to phot the profile, inthe second shot you can see the raised edge.
the Lobe/cam height measures:  34.32mm (1.352") versus nominal 1.360" and bottom service limit of 1.356".
Then the No4 Ex valve rocker follower:
you can see a slight 'flat' across the centre portion of the follower; that's probably lost a thou or so (?);
so in total that's say 5-6 thou' lost valve lift (bottom limit case; nearly ten thou' on nominals.
- I guess it could be much much worse?
but I'd welcome your opinion on my options.
AndyC
Post by: UK Pete on June 07, 2012, 09:52:07 PM
Hi Andy, i bought the neway cutters, they come up on ebay here and there or send of and buy them from USA , the head i did in that post was a Kawaski Gpz550 head, as this is the bike i am restoring at the moment, but they will also do my cb750 heads when i get round to it
Pete
Post by: Bryanj on June 08, 2012, 06:01:11 AM
That Cam is shot due to lack of oil, look at the bearing surface on the end.
Also check wether the rocker spindles that are in the cover have worn the cover oval, this can happen  although I've only seen one.
Still reckon your cheapest repair is a replacement head as guides and machining will be well over £100 plus £80 for pattern valves.
Camshafts and covers do come up on ebay---don't forhet the USA BUT remember there is only airmail now---Unless you plan on a holiday or know somebody who is
Post by: matthewmosse on June 08, 2012, 10:08:59 PM
California Connection / AP incorporated inport US bikes and often have engines, last time I needed one it was £150 for a unknwn quantity engine or £300 for a tested one plus £60 for pallett delivery so I had 2 unknowns to make the best of the deal - one was mint to look at but kept eating tensioners so wound up with bent valves - never did find out why. Other is in my 500. Given ebay prices at the moment I'd look at a complete engine from them if available and if the price is still in that ballpark.
Post by: andy_c101 on June 13, 2012, 08:38:00 PM
I'm hoping to pick up a camshaft off of fleaBay.
& I've ordered valves n guides off CMSNL (D/Silver didnt have the full sets)
I managed to extract the valve guides (I pre-heated the head in the oven at "60" for ten minutes - like we do to 'warm the dinner plates'; .... shhh don't tell you-know-who!)
I have a question (request advice) regarding cylinder/bores.
- I've used a bore dial gauge to measure each bore, tdc/bdc/mid-stroke, in a couple of places (each cylinder), and all measure within 58.50-58.52/.53mm (within service limit of 58.60mm);
piston ring gaps (side & end) all measure within service limits;
So my question: What would folks on here do/recommend?  - just rebuild as-is? or renew rings and/or more?
Andy C
Post by: andy_c101 on June 14, 2012, 11:12:55 PM
Yes, oddjob,
I've got a full gasket set, inc the lower gasket & o-rings.
I'm going to take advice on the bore condition ( I think they're ok).
& yes I'm looking into renewing the rings
cheers
Post by: UK Pete on June 15, 2012, 08:07:34 AM
lightly/ hone cylinders and renew rings, then you know its all done properly
Pete
Post by: andy_c101 on June 19, 2012, 11:21:57 PM
Pete,
I guess I need to find a local honing m/c shop.
- is there a way of 'breaking the glaze, very very lightly with with v/fine emery cloth ? or is that just plane stupid?
Also whilst the barrels are off, anyone got anytips on how to ease-off the base cylinder gasket? mine is well stuck!
- 3-in-1 oil? hot air gun?.....??
AndyC
Post by: UKROBK7 on June 20, 2012, 06:27:23 AM
I bought a Sealey 3-finger hone off ebay for about £10 and adjusted it to give light pressure to break the glaze on my bores.  Be very careful as you can "bell mouth" the bores i.e taper the top and bottom, you can also go too far with removing metal.  Don't let the hone fingers come too far out of the bores, I used a low speed on my variable speed drill and plenty of oil and moved the hone in and out at a steady rate.  Problem was I had to strip the hone and take sharp edges off the mechanism to get it to adjust the pressure correctly (made in China??!!).  I only gave the bores a light hone and was really pleased with the result giving a nice cross hatching to the bores.  I understand a ball hone is better but I found they were expensive for a one off job.
I have used emery cloth in the past on an old british single engine, I wound the emery around a piece of dowel and stuck it in the drill to make a sort of flap wheel.  It worked but I don't know about using it on 4 bores of a precision instrument like our Hondas! :D
If you use an engine m/c shop make sure of the quality of their work.  I used a local shop (who do competition engines) to do some valve seat cutting and they cut the seats wrong and nearly ruined a new set of valves, I'm glad I never used them to hone the bores - I can't imagine how they would have ended up.
Good luck
Rob
Post by: Bryanj on June 20, 2012, 07:03:00 AM
You used to be able to get thingd called Flap Wheels which were a steel spindle with emery cloth on and if you got one a tight fit in the bore that would be ideal as a glaze buster.
Post by: andy_c101 on June 26, 2012, 08:16:51 PM
Right...  the kit is slowly coming together.
I've gotten hold of a great camshaft, in virtually perfect condition!
I'm going to carefully try the sealey light honing tool (suggested by RobK7) to de-glaze the bores & fit new rings.
Have already de-coked piston crowns and cyl/head.
I'm going to see a local place for bead blasting rocker/head & barrels whilst it all apart.
Got new Honda Valves & Guides from CMSNL.
On this last point, the guides do need reaming (just as BryanJ said).
I think I'll need to try D.Silver for the guide driver & the reamer.
Next task will (probably) be to lookout for a Neway valve cutter tool (as mentioned by UK Pete)
Only glitch is I have to take to 'troops' on holiday next week for ten days, so that will add a further delay.....
-it could be a slow process, this rebuild!
Andy C
Post by: andy_c101 on June 28, 2012, 12:07:12 AM
Whilst the barrels are off, I am planning on changing camchain,but will need to split it to feed-on the new one, then rivet that.
I thought my push-bike chain rivetter would do, but the camchain pitch is much smaller.
Anyone know the tool number for splitting/rivetting the camchain?
CamChain is: 219T-088
Post by: Bryanj on June 28, 2012, 05:50:48 AM
That tool is expensive for a one off job, used a grinder to split and two hammers to re-rivet the new soft link (500 twin one if you didn't get one with the chain)
Post by: andy_c101 on July 09, 2012, 03:01:37 PM
Ref my Valves & guide from CMSNLs
CMSNL say they should NOT need reaming ! ??
& now ask me to return the parts?
I suppose I had better do that; but it will add further delays,
 and makes me start to loose confidence.
That's all for now
Post by: andy_c101 on July 13, 2012, 03:47:25 PM
I'd like to get a second opinion on calculating the acceptable limits & fits for the valve guides I/dia?
see attached info.
my calcs for the I/Ds workout at:
Inlet: 5.460/5.500mm
Ex:     5.460/5.495 mm
Post by: Bryanj on July 13, 2012, 04:34:01 PM
I never bothered to work it out! Just used the Honda reamer and left it at that
Post by: Tomb on July 13, 2012, 04:35:10 PM
I recently checked GSXR750 valves against the Suzuki factory manual, a mechanic mate was doing the head for a customer and couldn't understand why the valves were worn below bottom size with small amount of miles on the engine.
I measured the valve stem along its entire length, it was under all the way along, even the part that had not been in the guide, the finish was the same all along so it was obvious the guide area had not been bigger and worn down. The valves were all under size from new. Whether this was an engine mod Suzuki'd done later on and not updated the manuals I dunno. Check your stems all along the length before condemning them.
Your PDF manual chart shows 3 thou clearance for inlet and 4 though clearnce for exhaust as "serviceable limits", that is 'kin massive clearance!! known as piss fit in engineering. I'd be surprised if your valve to guide wear was that bad
To me its not the I.D's of the guides that matter most, its the "fit"  3 or 4 thou is a rattling piss fit. A nice fit is smooth gliding up and down of the valve in the guide with some oil on it, with no side play.
Sorry for so much waffle, crap at explaining whats in me 'ead ::)
Post by: andy_c101 on July 13, 2012, 06:37:29 PM
Yeah I tend to agree the actual bore dimensions alone, are somewhat academic, yes its the actual fit that counts.
- I've got a Honda Reamer on order, just waiting....
Post by: andy_c101 on September 01, 2012, 10:08:25 AM
Still waiting on David Silvers supplier for my valve guide driver & reamer.
"ETA is now end of September" !......yawn.
Post by: andy_c101 on October 10, 2012, 09:46:36 PM
Valve Guides now installed!!! :)
Boy! It has been a long saga.
Summer has been & gone off the road (but I didn't miss much this year!)
After a  long wait for the Driver tool (No 07942-329-0200)  & Extractor tool (No. 07942-329-0100).
I carefully followed the prescribed heat-n-freeze method.
Only to end up cracking the flange of the first valve guide !!
The Driver Tool is like a blind-hole socket, but it only contacts the flange of the guide.
(used Genuine Honda guides)
Plan B:  used the Extractor tool  to INSTALL, as this is a snug fit with the I/D of the guide and buts squarely at the top of the guide.  (I had realised the extractor removed the old guides fine, without damaging the ends, so I thought why not use it for installing?)
So while house was empty, did some baking!
 Heat-Freeze & lube oil. ...Bingo!....went in nicely with just a few taps.
Reamer worked a treat too.
just some valve lapping to do.
AC
Post by: andy_c101 on January 13, 2013, 08:13:00 PM
Been too busy to post, but after a long long time, at last the K3 is alive again and breathin' fire! ;D
- new guides/valves/re-cut seats/honed bores/new rings/camshaft/chain/blasted 'n painted casings
- buttoned down the head this w/end; set valves & points
- fired her up, Bingo she runs! On the button, first time (well 2nd actually)
- probably could do with re-balancing the carbs
then we're ready to rock n roll....
Ah! they say its gonna snow, Doh.
I don't want to pick up any of that nasty road salt, guess I'll have to wait. :(
But its a good feeling to 'bring her back to life after all these months.
AC
Post by: mickwinf on January 13, 2013, 10:26:25 PM
well done mate its a great feeling !
