SOHC.co.uk Forums => CB750 => Topic started by: Bitsa (Ralph Wright - RIP) on June 11, 2012, 09:13:50 AM
Title: 750 carb linkage
Post by: Bitsa (Ralph Wright - RIP) on June 11, 2012, 09:13:50 AM
Hi all,
Has anybody got a fix for where the cable goes on to for opening throttle apart from the obvious?
Sorry for the photo but you can see one side has broken off.
Bitsa
Title: Re: 750 carb linkage
Post by: Waggles on June 11, 2012, 12:03:25 PM
I'd go for 'the obvious'. Am sure you could weld a new bit on or maybe even through bolt a suitable patch but you are going to have to dismantle anyway and it would probably be more hassle than just replacement.
Its a bit hard to see but doesn't it still work OK like that?
Post by: Bitsa (Ralph Wright - RIP) on June 11, 2012, 02:40:38 PM
Waggles cheers for that yes it does work only saw as I was messing with carbs and as it happens after posting this I found a new one in a box of bits and just finished fitting it.
The x head screw was a bugger to get out apart from that sorted now.
Bitsa
