General => New Member Introductions => Topic started by: StPeter on June 15, 2012, 09:54:55 AM
Title: New member says Hi
Post by: StPeter on June 15, 2012, 09:54:55 AM
Greetings from Northamptonshire.
I'm just about to collect a CB500; It's registered 1975, in brown and mostly original apart from the pipes. Some cosmetic work required but it's a runner (it says here!). I've wanted one ever since I started biking back in the 70s so I'm looking forward to getting to grips with its wrinkles and foibles and will be unashamedly picking brains here to help me do it!
Thanks in advance, Pete
Title: Re: New member says Hi
Post by: UK Pete on June 15, 2012, 10:01:10 AM
Hi Pete welcome to the forums
Pete
Post by: Bitsa (Ralph Wright - RIP) on June 15, 2012, 11:27:34 AM
Welcome dont forgot any photos
Bitsa
Post by: mickwinf on June 15, 2012, 01:35:15 PM
Hi Pete lots of help on here for us 500/4 owners, regards Mick
Post by: SteveD CB500K0 on June 15, 2012, 02:45:23 PM
We can talk about Tigers here too if you like  :)
Post by: florence on June 15, 2012, 05:43:57 PM
Another 500/4, hoorah!
Post by: StPeter on June 19, 2012, 11:13:43 PM
Thanks for the welcome. Here's a pic of the new addition complete with puncture, leaky No 4 carb and (as I found out tonight) broken clutch pushrod. Apart from that, it's perfect.  ;)
P
Post by: florence on June 21, 2012, 08:53:56 AM
Very nice.  I had a leaking carb on mine.  I took off the float bowl and found that the float height was correct and the needle valve worked when I pushed the float up with my finger.  Mysterious; on closer inspection it turned out that the brass tube which comes up from the overflow pipe had a tiny crack in it and this was the cause of the leak.  A careful smear of araldite effected a perfect lasting cure.
Post by: kifer on June 21, 2012, 11:12:15 AM
Welcome bike looks well tidy, you will have no problems getting it sorted lads on here know all there is to know good luck  :)
Post by: Spitfire on June 21, 2012, 06:42:01 PM
Looks great, I'm a bit partial to the CB500/4, great for swinging round lanes.
Post by: StPeter on June 21, 2012, 09:51:53 PM
The bike's pretty photogenic - it has its tatty bits but the tank and side panel paintwork is really good. Just started the spending with new cables, levers, grips etc.
I've read threads here on the split overflow pipes and checked for that - I think the float height was wrong I've yet to hook them up to the tank again to check but I have my fingers crossed. I'm trying to keep my polimania in check but the sprocket cover does come up a treat . . .  8)
Post by: SteveD CB500K0 on June 22, 2012, 07:27:39 AM
Got me there.
Polimania?
Google says its a printing company in Poland...
Post by: LesterPiglet on June 22, 2012, 09:37:09 AM
Got me there.
Polimania?
Polishing fetish. :)
Post by: StPeter on June 24, 2012, 12:52:16 AM
There are recognisable signs which identify sufferers; shiny black fingernails on one hand and a black line running up the nose on to the forehead.
Post by: florence on June 25, 2012, 10:33:40 AM
I think I must have 'rustimania'.
