SOHC.co.uk Forums => CB750 => Topic started by: Lobo on December 21, 2012, 06:10:52 AM
Title: CB750 Caliper rattle
Post by: Lobo on December 21, 2012, 06:10:52 AM
New back to biking after 30yrs - and can't find any tolerances / specs on this.  Basically my 1971 K2's caliper moves up & down by upto 1/8" due slop in the carrier. This pin (I guess) is OK as a snug fit into the upper / lower caliper holder mounts (& shows no waisting) - so the play is within the holder itself. This translates into a fairly mechanical 'clunk-clunk' noise when transversing bumps etc  at low speed. It, of course, goes away if any drag on the brake.
I pointed this out at the recent MOT - no concerns at all. So, is it normal, and if not any suggestions eg bushings - or am I up for a new holder? I read in the various maintenance manuals about calipers seizing on with lack of use - can't ever imagine mine seizing with this amount of free play!
Cheers.
Title: Re: CB750 Caliper rattle
Post by: Waggles on December 21, 2012, 07:15:34 AM
As you so rightly say, they are more prone to seizing than excess play so I'd say no, its not normal, mine certainly doesn't do that. It may have got through the MOT but I wouldn't be happy with it, the slopping around could cause damage.
Dunno the cost of new but I would replace arm and possibly spindle too ( it may look OK and the arm will wear first but it might be damaged ) a good second hand set shouldn't be too hard to find if cost is an issue
Post by: florence on December 21, 2012, 08:36:44 AM
That does not sound right to me.  I would take it apart and inspect.
Post by: Bryanj on December 21, 2012, 08:47:21 AM
There is a Honda bulletin on this, bug me early in the new year when I ain't dragging booze round the country for god knows how many hours a shift and i will find it and scan it!!
Post by: Lobo on December 21, 2012, 11:06:09 AM
Thanks guys, thanks Bryanj,
Yup, had the thing apart (twice) and have to say, nothing particularly alarming. There is minimal slop in the pin, but, I guess when magnified 6" away at the caliper head it does become quite apparent.
I'm a little 'reluctant' to simply buy a second hand carrier off ebay etc, as in all likelihood I'll simply end up a similarly worn part.  Hence my question on bushings...
Will now wait to see if Bryanj can shed light.... thanks again so far
Lobo
Post by: steff750 on December 21, 2012, 02:44:12 PM
 ;) there are two sizes of shim in the parts list 0.1mm-0.2mm,that can be fitted between the lower part of the caliper and the caliper holder ,use either one or the other or even both as the parts list shows you can have any number of shims :o . i have seen this so many times that i would say that it was a common fault,and as the shims are not shown in the first parts list but they are in the fourth parts list . i would say that honda tried to correct the problem (bryan said there is a parts bulletin for it), and i have seen so many calipers without shims anyway. and yes i would say you would probably buy a secondhand one just has bad as yours. my advice would be get the shims and go from there,may aswell get the two orings while you are at it and grease the pin 8)
Post by: Lobo on December 21, 2012, 04:23:51 PM
Steff - I think you've just fixed it! Thanks.
Whilst I do indeed have those O rings, there are no 0.1  / 0.2 mm washers. And whilst the slop appears  minimal at the carrier head it is not so at the caliper, ie seems I just now have to find those spacer washers......
Many thanks again,
Lobo
Post by: K2-K6 on December 21, 2012, 09:20:07 PM
Because they only rotate a very small amount it's unusual to get a significant wear on either component, but this is why they end up siezed when not greased.
If you are saying that the caliper support is moving by sliding up and down the pin, then shiming should be a reasonable way to cure that.
If the caliper support is moving in an arc i.e. the hole is too big for the pin, then the problem would seem more serious. Any plan to use a bush would be difficult as the material around this location is maybe not generous enough to make an adaption.
Title: Lobo
Post by: Lobo on December 22, 2012, 12:40:46 AM
Hi K2-K6,
Agreed, and yes, it does move in an arc - suggesting hole wear? I figured if a spacer were slotted in between all mating faces then this would arrest any 'nodding' of the carrier. The fact that Honda show optional washers in the parts diagram, and Bryanj mentions a Bulletin, all attest to the fact that it may be a known problem. Surely Honda wouldn't bother supplying a washer to stop a 0.1mm slide up & down the pin - but I could see it as a preventative measure to minimise exagerated nodding at the caliper.
Have got to add, it is not as alarming as it all sounds... which is why I guess the MOT man wasn't concerned. I've had it all stripped down, there's no obvious wear, or signs of abuse etc. My main gripe is the odd clunk over bumps etc.
The bike was semi-restored when I bought it, and perhaps the carrier had been seized at some point and subsequent corrosion removal has taken material away too. In which case I'm up for a new carrier...
But will try a spacer first...
Cheers, Lobo.
Post by: Bryanj on December 22, 2012, 07:07:41 AM
OK just finished another booze run and found the bulletin so here you are
Title: Lobo
Post by: Lobo on December 22, 2012, 09:41:57 AM
Thanks Bryan for taking the trouble.
Not certain (after all) it describes my problem and thinking I'm in for a DSS £100 new carrier.
Ah well, tis Christmas after all....
As a general note to all out there we should perhaps bear this in mind if considering a second hand carrier off ebay!
Cheers,
Lobo.
Post by: K2-K6 on December 22, 2012, 11:00:05 AM
It does seem that the bulletin deals with a "float" along the shaft that results in a clunk as the caliper mass is moved, and seems to be the right way to control this.
The load path of the pivot axis is arranged so that when the caliper force is applied (braking) then the full length of the pivot is used (this is because it sits partly outside the disc swept area and differs from the fork angle). This is a good situation and should not result in undue stress or integrity during braking as it will natuarally align due to the braking forces. I don't think at this level it's any compromise to safety at all as it essentially has a design to cope with this.
Think you are right to try shims in order to control the movement and clunking when the brake is not in use which is just annoying rather than a particular fault. I have heard it on others over the years so it's by no means isolated.
If it was mine, I'd go with the shims as I've never seen a failure of this part.
One other consideration is the bolts used to fix the brake to the fork leg, these have to be of the correct type and would ordinarily have a dowel type shank that locates the braket in it's correct position and gives positive location, if these have been swapped for bolts with threads right up to the bolt-head then that function is lost and can contribute to spacing issues.
Title: Lobo
Post by: Lobo on December 22, 2012, 01:52:48 PM
Thanks K2-K6,
DSS had 01 OEM Carrier in stock, a couple of pins,  one 0.1mm spacer & nil 0.2mm. I won't be near the bike until NY day, and so simply thought 'sod it' & ordered the last carrier, pin & shim. My problem is I can only get hands-on with the bikes a couple of days PCM, and to order / play with shims, find not cured & thence DSS nil more carriers was too much to bear!
And ta for the heads up on the shank bolts - will take a look.
The issue, I am 99% sure, is the 'nodding' of the caliper - it was getting silly in that to stop the annoying clunk I was involuntarily applying slight front brake over bumps. Furthermore the Honda bulletin descibes a different problem (seemingly) to what I was experiencing - ie clunk with brake.
Again, thanks for your help.
Cheers, Lobo.
Post by: Bryanj on December 23, 2012, 11:08:51 AM
OK the pin should be a tight fit with no play in the static bracket and a sliding fit with minimal play in the swinging bracket, it is unusual to get excess play in the swinging piece and I have never seen play in the bolted piece, excess play can only be caused by over exuberance of cleaning corrosion after a siezure(which was very common---siezure that is)
Title: Lobo
Post by: Lobo on January 01, 2013, 05:51:20 PM
Anyone able to help with my caliper carrier - which now doesnt seem to be K2 spec. i ordered DSS p/n 45115300030 only to find its visually identical (almost) but about 1/2" longer than my carrier, and with the stopper bolt hole further down towards the caliper. It fits the holder, but is unusable due stopper bolt hole position...and length!
So...don't know what my bike has - are the forks non-CB750K2?
Out of interest (to the preceding thread) both carriers (old & incorrect new) have (approx) 0.3mm slide up & down the pin. The pin is new, and both carriers exhibit slight nod at the caliper - no play detected in the bolted holder. I fitted the one and only washer DSS had (0.1mm) - which isn't enough, but did lessen the 'nod'. I am (almost) convinced a little more spacings (as per the Honda bulletin) may solve my problem. ie it may simply be the 'Joint -Caliper holder' (ie bolt on piece) jaws are minimally too far apart?.
So...still looking for a Honda 0.2 mm spacer....
Title: Lobo
Post by: Lobo on January 01, 2013, 07:38:57 PM
Thanks OddJob... will pm you. These darn washers getting a bit rare it seems....
Post by: Seamus on January 02, 2013, 11:15:10 AM
can you not measure the float with a feeler gauge and buy a bit of shim stock to make one?
Title: Lobo
Post by: Lobo on January 02, 2013, 07:08:59 PM
Hi Seamus.... guess that's a 'Plan B' as I'm happy to spend £3 on the washers if I can get them.
Post by: Lobo on January 02, 2013, 07:21:54 PM
Thanks OddJob...fingers crossed.
Post by: Bob Wessner on January 11, 2013, 06:19:52 PM
My first post here. It took me some time to isolate the clunk, but once I had decided it was the caliper assembly bouncing due to too much play (really evident crossing railroad tracks) I went to my local hardware store and bought a few small sheets of brass stock in a couple of different thicknesses. It was thin enough to cut with scissors, though I don't recommend using your wife's good sewing shears  ;). After that it was just a matter of punching a suitably sized hole in the middle and installing it. No clunks since.
Title: Lobo
Post by: Lobo on January 12, 2013, 04:00:35 AM
Thanks Bob. You're the first to actually state the exact same experience, and better still to verify the shims appear to be the answer. Hoping to find the OEM shims still, but will go your route if no success soon.
Cheers.
Post by: Lobo on January 13, 2013, 01:21:46 AM
Great news, cheers OddJob.
Have just PM'd you...... I think!  (recipient address kept hiccuping back to 'Lobo')
If no PM can you pls advise,
Cheers, Lobo
Post by: H2Eric on January 17, 2013, 06:09:55 PM
Could be wrong, but the longer one may be from a later model. Is the caliper arm symetrical when viewed from above? early ones were, but I think the later ones had the pin slightly offset to the lefthand side.
Eric
Title: Lobo
Post by: Lobo on January 18, 2013, 06:00:43 AM
Hi Eric,
Yes it is - in fact you can almost see that from the picture, ie the radiusing from the pin to the carrier versus my current piece. (see pic page 1 of this thread)
DSS supplied it wrapped in official looking brown paper & the part # written on that - but no actual OEM bag or printed Honda part #. They obviously think its K2; but if it is then my forks are wrong as the stop-bot hole does not line up.
Notably the my current carrier has the digits "1 - 9" embossed towards the end, and this new part simply "7" (seen if pic enlarged)
Anyone suggest which part is correct for the K2 (Frame 2077...), and which bike the other part may belong to?
Cheers...
Post by: Bryanj on January 18, 2013, 07:48:20 AM
Question on your forks:-
Is there an allen bolt inside the axle clamp half circle going upwards(on the slider)
OR
do your forks have Bushes or do they run direct on the alloy.
As to the bracket it changes on the K3
Title: Lobo
Post by: Lobo on January 18, 2013, 09:44:45 AM
Hi Bryan,
Yup, see the K3 mod with the 'internal' Allen bolt .... give me a while as not inclined to dismantle the bottom forks in the detached minus 2 deg garage....
The later K2, & K3 onwards carrier (#13 below) has a totally different look about it from the parts diagram, and not at all similar to the DSS part I've been sent - which looks identical to the early K2 carrier (#12 below) but is dimensionally a tad longer, with stop-bolt hole displaced.
My front mudguard mount (ie forks 'tie' piece) is the older style, ie pre frame 2093730 -suggesting my forks earlier K2?.
I remain confused!
Post by: Bryanj on January 19, 2013, 11:19:01 AM
Forget the illustration, all those I have seen look like the ones you have mate
Title: CB 750 Caliper Rattle
Post by: Lobo on January 21, 2013, 02:03:41 PM
...got the shims in this morning & the caliper play (nod) disappeared.
Regarding the carrier (correct for my K2 or not?, & see photos at bottom of page #1 this thread) it is 150mm overall length, versus the DSS new part which is around 165mm long. Still remain a little unsure which carrier is correct, tho' can't yet confirm Bryan's query over the forks.
Post by: Seamus on January 21, 2013, 06:39:05 PM
The one in my box of bits is 150mm. It is a K1 part, which carried on into early K2. Later carriers had  T piece mounts that bolted to the forks. Guessing that that carrier could have been longer.
Hope that helps
Title: Lobo
Post by: Lobo on January 21, 2013, 09:14:48 PM
Thanks Seamus,
This ties in with my (early) K2 frame #2077.... so I'm left wondering what part DSS sent me. (does look awfully similar, and prob could not tell unless other part to hand)
Post by: Seamus on January 22, 2013, 11:26:28 AM
Part no 45115-300-030 caliper carrier fits K0, K1 and early K2 as well as the early cb450's.
I guess the longer one (part no 45115-341-670) was for the T piece mount as fitted to the later K2 onwards.
Anyone care to measure their K2 on carrier length to proove the point
Post by: Lobo on January 22, 2013, 01:59:46 PM
..... and further to Seamus's post we're asking the overall length of the carrier on the 750 K2 frames onwards from #2093731, OR the K3,4,5 models (for thems with American imports)
Thanks..
Post by: Lobo on January 25, 2013, 09:08:54 AM
Cheers all, having seen Bryan's comments re forks / & "don't believe the parts pictures as accurate", and Seamus's about the later models T piece set-up 'anchoring' of the carrier (which is likely sited further aft) I reckon my bike is standard (phew) & DSS have sent out the later part#. All borne out by frame #s / fork #s and the different configuration of the later forks versus mine.
What a bloody waste of time....and a slow leaning curve for me!
Thanks...
Post by: Bryanj on January 26, 2013, 05:44:54 PM
If you talk to DS I will bet you they will refund you, including postage, as  long as you explain that the part appears to be incorrect to part number
Post by: Lobo on January 27, 2013, 09:10:00 AM
Cheers Bryan, yup.... plan to do this now 'positively' at the bottom of the problem.
Thanks again,
