SOHC.co.uk Forums => Other Bikes => Topic started by: billy192 on December 22, 2012, 09:38:38 PM
Title: Valve timing
Post by: billy192 on December 22, 2012, 09:38:38 PM
Hi,
I think I have put the cam back in correct,,,,,,,,, but is there a way to make sure. I have turned the roto around by spanner and not valves hitting the piston. but doubt has crept in.
I do know where TDC is but how do i know when TDC on the compression stroke is?
Billy
Title: Re: Valve timing
Post by: tom400f on December 22, 2012, 10:02:03 PM
I would expect the static ignition timing marks will tell you (this is a 250G5 right? They are 180 degree twin if I remember)
Anyway, if you have aligned the crank and camshaft markings OK then its unlikely you have made a mistake. You have to be a whole tooth out one way or the other so it would have been obvious. Not sure how easy it is to measure accurately but if you know the timing specification (inlet opens x degrees before tdc etc) then you can may be see with the tappet covers off and check the crank position.
Last resort - whip the rocker cover off....
Post by: billy192 on December 23, 2012, 08:31:41 AM
Thanks,
yes its a G5 250 I think its dead on the timing marks. after checking last night it looks like the carbs are not working correctly. the slides are not rising at all. i will check the diraphram's next.
Billy.
Post by: K2-K6 on December 23, 2012, 01:29:53 PM
To answer your original question about compression stroke......it's the cam that defines the compression stroke as if you move it one revolution out from where it is the compression stroke moves with the cam, if that makes sense.
The other part of your concern you seem to have covered yourself in that the timing accuracy is correct as even one tooth out will show as a deviation on the marks.
I always think it's good practice with turning by hand as you've done, if it meets any resistance at this point at least you can work backwards through it to correct it without bending a valve.
Post by: billy192 on January 13, 2013, 06:28:48 PM
Hi,
Ok update. got the engine running, well running on one cylinder. the Left is purring like a cat the right nothing at all.
things i have checked
1 spark ....yes
2 fuel ... yes plug is wet when i take it out
3 swapped around plugs still the same
4 swapped the diaphragm from each carb
5 cleaned all jets
6 points  gap checked more than once
7 used a bulb on the points to the left and light comes on when LF on stator
8 if i rev it up i get a bake fire on the right once
9 can the engin run like this with the cam in 180 degrees out?
fed up as i am nearly there :'( :'( :'(
Billy
Post by: Bryanj on January 14, 2013, 05:40:57 AM
Are you re-fitting the points cover as it was a common fault for the cover to earth out one set of points
Post by: billy192 on January 14, 2013, 07:38:22 AM
No points cove not on  :(
Billy
Post by: andy_c101 on January 14, 2013, 09:47:34 PM
I've not worked on the 250G, (so this is more speculative, & not authoritative)
but my experience on a 550 points timing, I find that I can set the static points timing with a bulb, to light on the "F" mark, BUT.... I then have to be extra extra careful that on re-tightening the points baseplate, that nothing moves.
I go round the (three) baseplate screws by just a fraction of a turn to tighten it it all down so that nothing moves.
- in the past. that has caused me to 'loose' ignition on one coil.
Otherwise be methodical, and patient; you will get there!
AC
Post by: K2-K6 on January 14, 2013, 10:04:24 PM
I see what you mean in asking about the cam being 180deg out......but trying to think through it I'm struggling with the sequencing to come up with any answer.
It is a 180deg crank on this bike? isn't it?
Are the points running on the crank?
As another thing to compare....can you switch the points wire to the opposite coils and also the plug caps to in effect swap the coils over to verify if both are ok.
Post by: billy192 on January 15, 2013, 12:46:29 PM
Thanks for the reply K2-K6
spent hours on U tube last night found a great guy timing a CB360 1974 virtually the same engine.
he was changing the points gap to suit the timing marks and said to disregard the manual when it came to timing.
so currently i have the right points gap at 0.040 and the left at 0.030 and both cylinders are firing,,,,not smooth but BOTH firing.
so i feel some minor tweaks and I will be there.
 Billy
Post by: K2-K6 on January 15, 2013, 04:21:38 PM
Well that is progress and at least allows you to move it closer to running well.
I researched a bit more about the firing intervals of these engines to try and answer the original 180deg question you posed, and as far as I can see it should make no difference as the ignition operates on a spare spark principle i.e. it also sparks during the exhaust stroke  as well as compression so if the cam was out by 180-crank-deg then it should still run on both cylinders.
If anyone else think that's wrong please add to this.
Just a thought about the points gap....if it runs better with a bigger gap, then it could be the condenser not functioning well as this is supposed to help the points switch cleanly....you could try switching the condensers over between each other to assess this.
Post by: billy192 on January 15, 2013, 10:08:17 PM
I think your correct with the cam. as for the condenser there is only one between the two sets of points.
i will keep fiddling til i get there
Billy
Post by: billy192 on January 16, 2013, 04:13:02 PM
Hi Oddjob,
It is one of those where you need to average out the gaps between both sets and they are both new and Honda.
will clean the advance mec tonight
Billy
Post by: billy192 on January 19, 2013, 07:33:01 PM
Sorted,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, took the plunge and striped the top end and yes it was 180 degrees out. I dont know how I did not see when I first did it.  Re set the valves which for some reason were way out on the right cylinder. started first turn checked with a strobe and a minor adjustment now sweet as a nut. thanks for all the advise.
Billy
Post by: UK Pete on January 19, 2013, 07:43:38 PM
Well done Billy, bet your well pleased,
Pete
Post by: billy192 on January 20, 2013, 09:39:58 AM
o yes,, i was getting to the end of my patients. now i need to get it MOT ed, just a few little jobs but to hear the engine running is great
Billly
Post by: K2-K6 on January 22, 2013, 08:19:16 PM
Well done for getting it sorted out, and a bit of a relief i guess.
I'm still trying to figure out what configuration it was in to do as it was doing, presume there were no damaged valves as well.
Good luck with the MOT anyway.
Post by: billy192 on January 23, 2013, 09:13:50 PM
Hi,
well it was running smooth now its popping through the right carb and if i rev it, it goes up to 5K and stays there until i turn the tick over screw.
the left seems to be running better than the right. my next move check tappets  AGAIN just in case. take carbs off AGAIN and clean and bench synk which to be honest i have not touched since building them.
Billy
Post by: K2-K6 on January 24, 2013, 09:45:27 PM
Have you got any means of checking the compression?
It's worth doing to help understand what's happening there for each cylinder.
Popping back through the carb suggests too much ignition advance if all else is in order.
It's frustrating but it just doesn't seem far off being ok, just a bit of a pain to keep going through things again....at least it's not summer when you'd want to be out riding more.
Post by: billy192 on January 25, 2013, 09:00:21 PM
K2 -
compression is 150 psi Left and 135/140 psi Right I have ordered a pair of kits so give the carbs a good clean and change all the jets. see if this helps. i did clean the old ones but they were looking poor.
Billy
Post by: K2-K6 on January 26, 2013, 08:24:32 PM
That shouldn't give you any real problems.......I was just thinking if the valves had been slightly bent on #2 then it could be spitting back through the carb, but I don't think the psi would be sustained that high if that were the case.
If anything you can leave the valve clearances slightly wide at this stage to make sure nothing is being held off the seats for any reason and it won't stop it running well.....refine them later when you get to the root-cause of the problem.
Is the advanc and retard mech working properly and not sticking?
Post by: billy192 on January 28, 2013, 11:48:29 AM
Yes the advance is working great.
I used a strobe light and the timing is spot on (well i think so) the first time I started it was running smooth on #2 i really think its carb sync and or blocked jets.
I know spitting back is valve timing so I am going to open the valve gaps a tad as you suggest I did do them quite tight as i hate the rattle they make if on the wide side.  plus it always sounds louder in the garage.
Billy
Post by: billy192 on January 28, 2013, 11:55:12 AM
Just thinking, (yes a bad thing)
the exhaust clamp on #2 will not seal. would this lack of back pressure make it pop through the carb intermittently?  or am my clutching at straws?
but as I am talking about it how do i get this clamp to tighten even more. I am afraid if I give it any more turns the bolt will snap.
Billy
Post by: K2-K6 on January 28, 2013, 07:11:54 PM
I know what you mean about tappety engines, I too like them smooth and take time to get them spot on when running well.
Leaking exhaust will give you some popping usually so worth trying to get it sealed....they normally tighten ok but it's worth taking the bolt right out and cleaning the threads with a wire brush then using copa-slip to make sure all the clamping effort is applied rather than any thread binding.....it's surprising what a difference this can make on that type of clamp.
As you though, I think it looks like the carbs are more prime suspect given what you've gone through already.
This is an odd one but can give a good/simple/cheap look at HT leads.....get the bike into as dark a place as possible and run it (with the tank off if poss) and you will see if the HT leads are leaking out to earth as the sparks, even if small, are easily seen......if any obvious sparks are there, then just move the lead away with a insulated screwdriver and see if the running improves. When they leak like this they can also make a fair impression of tappet noise when you are close as the spark has a real crack to it.
Post by: billy192 on January 29, 2013, 07:17:26 PM
sorted the backfiring.
after removing the carbs striped them both and yuk they were full of orange fine silt. When i put these together they were spotless.
(http://i1209.photobucket.com/albums/cc393/njwill1/photo3.jpg)
The only place this muck could come from was the tank l use. its a plastic ex mower tank i have had for a year or two. I  shook it well for a min and emptied it into my parts cleaner over a cloth and man was there a load of crud. not sure where this has come form as I have used this for several projects. hey ho. washed out and refiled with nice fresh fuel. the carb kits with postage from David (stand and deliver) silvers were £16 + vat + £5.68 post and lo and behold they were not the correct ones.
(http://i1209.photobucket.com/albums/cc393/njwill1/photo2.jpg)
so cleaned jets, floats and bowls refit and boom runs like a good un. after warm up I turned the air/pilot screw out about two more turns , as the rves climbed then turned down the tick over.
is it OK to have these screws out about 4 turns as the book says 1.5 turns.
p.s fuel  filters fitted on both pet pipes.
Billy
Post by: Bryanj on January 30, 2013, 06:30:48 AM
4 is a bit excessive, personally I would not go over 2 1/2. Are these the diaphragm type carbs as if so they always caused problems when the rubber got old and fuel impregnated and by christ didn't they cost a lot!!
Post by: K2-K6 on January 30, 2013, 08:30:38 PM
Agree with Bryan about being a bit much over 2 1/2 turns out...but would try to run it first and see if it will then accept a smaller difference once it's good and warm after a cleanout run-around.
At least you seem to have got to the bottom of it and had a good sort through all the setup to boot.
For a long time I've used a 150ml clear medical surringe with the plunger removed and pushed into the carb feed line to run bikes with the tank off.......you can just fill from the bike tank as you need and can easily see if the fuel is clear.
Is it going for Mot now?
Post by: billy192 on January 31, 2013, 12:34:35 PM
Need to fit frond badge and the reflectors then MOT i have the original plate not sure if will pass the MOT it is the correct size and correct letters but the British Standard and company name are back from the 70s.
I will take the pale into him first. I cant buy a new one as i have no log book.
Billy
Post by: Bryanj on January 31, 2013, 04:04:52 PM
Should be OK as the only retroactive part of the mot standard is the  size and style of the letters---and that is different from cars
Post by: K2-K6 on February 02, 2013, 04:52:35 PM
Further to your fuel problem; was speaking to a friend last night who works in the bike trade in America, north east coast area, he tells me that they are having all sorts of problems like this which they attribute to Ethanol blended into the fuel at maximum of 10% (UK can be 5%).
It's interesting as they have a lot of bikes layed up over the winter and many problems in recommissiioning them with almost all needing carb strips etc to clean them out.......even having problems with some new bikes if they are PDI'd and wait around too long, then having to carb strip a brand new bike to get it running properly.....also problems with rubber tipped float needles going hard and then not sealing when used again.
The common consensus for laying the bike up for winter is leaning toward running it for a short while on Avgas or Race fuel as they have no Ethanol content currently......the idea being to purge any regular supply right through the fuel system and leaving the carbs dry during the storage. he's not done this on one of his bikes yet but intends to try it out.
It could be what has stripped out your temporary tank to give you that gunk you had.
Post by: billy192 on February 02, 2013, 07:49:02 PM
its possible
Its running great now I still  have to have the air screw out 3.5 turns or it runs lumpy. I also have a small oil leak around the head gasket I think.
I will post under a new topic.
Billy
