SOHC.co.uk Forums => CB750 => Topic started by: ianmck on April 13, 2013, 08:29:11 PM
can anyone give me some advice, I have a couple of damaged cooling fins on the engine, any ideas on repairing them, the engine is out but I dont want to strip it if poss.
I used an epoxy clay to replace a chunk out of the very top fin on my 750. That was about 6 years ago and it's still there, no problems.
Finally found the thread where this was discussed (U.S. Forum) and the product I used. Hope it is of some help.
http://forums.sohc4.net/index.php?topic=19402.msg202306#msg202306 (http://forums.sohc4.net/index.php?topic=19402.msg202306#msg202306)
Bob you are a star, thank you for your efforts, I will try to find the same or something simmilar over here. thanks again, Ian.
Devcon, if its still made, used to do a metallic based epoxy putty for all the different metals
Wasn't aware of this one. It appears Devcon is still available but at this site it's pricey and the quantity is a bit much. :-\
http://www.ellsworth.com/devcon-aluminum-putty-f-1lb-kit/ (http://www.ellsworth.com/devcon-aluminum-putty-f-1lb-kit/)
Used the steel, brass and alloy types when in the merchant navy Bob. When used correctly it will take a thread as long as you dont want extreme torque. Also used some etuff called Thistlebond that i havent seen for a while----was a woven glassfibre bandage along with a resin and hardener, didn't half get hot quick and burnt fingers!!!
Bryanj, looks like Thistlebond is still around also.
http://www.thistlebond.info/products/engineering/metalrepair.htm (http://www.thistlebond.info/products/engineering/metalrepair.htm)
Where were you with all this knowledge six years ago when I needed it? ;D
Sorry Bob, was building No 36 for the first time i think!
The Thistlebond I remember was
http://www.thistlebond.info/products/addedinfo/TRK2006.htm
Never knew of the other stuff, it was the Devcon for that.
All the best mate
