SOHC.co.uk Forums => CB350/400 => Topic started by: Boggieman on May 09, 2013, 03:44:04 PM
Title: Carb question
Post by: Boggieman on May 09, 2013, 03:44:04 PM
Hi Guys
I am thinking of fitting some pod style air filters to my 400/4 race bike. Does anyone happen to know the outside diameter of the intake mouths to the carb's?
I can always take my airbox off the bike but thought I would ask on here first.
Thanks in advance
Ian
Title: Re: Carb question
Post by: Dan on May 09, 2013, 06:37:32 PM
I've seen pod filters advertised specifically for the 400, they were 35mm. You can get short filters that won't rub on the frame.
Alternatively, what I have done is remove the paper element from a standard air filter and replace it with foam from Ramair. It cost a fiver and there is enough foam to do 2 filters this way. You get to retain the air box this way which may be important to some.
Post by: Piki on May 10, 2013, 07:54:15 AM
Hello, I have the carbs off the frame, this afternoon I will measure the diameter and let you know.
Where I can get RAMAIR foam??
Thank you.
Post by: Boggieman on May 10, 2013, 10:27:41 AM
Thanks for the replies gents.
Piki, If you do a google search for Ramair Filters, they should come up.
Ian
Post by: Dan on May 10, 2013, 03:31:06 PM
http://ramair-filters.co.uk/automotive-accessories/air-filter-foam-material-universal-fitment.html
You need to scrape out the glue that secures the paper element to the metal frame of the filter.  When the foam is cut to size it stays in place, held by the lip of the edge of the frame.
I did this, and went up a jet size, to suit the Marving exhaust on my bike.
Post by: Piki on May 10, 2013, 10:21:13 PM
Thank you, I bought RAMAIR by EBay, is cheaper than web site!!
Boggieman, Tomorrow or Sunday I Will go to the garage and I measure the carbs for you.
Post by: Piki on May 11, 2013, 12:34:53 PM
Boggieman look:
<a href="http://www.casimages.es/i/130511015343694180.jpg.html" target="_blank" title="subir imagenes"><img src="http://nsae01.casimages.net/img/2013/05/11/130511015343694180.jpg" border="0" alt="subir imagen" />[/url]
Post by: Boggieman on May 13, 2013, 08:58:46 AM
Hi Piki,
That's great thanks.
Ian
Post by: Piki on May 14, 2013, 04:45:58 PM
Hello Again,
The RamAir Foam Just arrived at home and I have one dout, what position is the correct to install?? The Foam has ‘two colours“ one side black and grey the other side. Is indifferent the position?? The Grey side next the box air or the black??
Thank you in advance.
Post by: Dan on May 18, 2013, 11:46:35 AM
Hi Piki
The more dense foam (grey) goes on the inside.
Dan
Post by: Piki on May 18, 2013, 12:41:56 PM
Thank you very much Dan!!
