SOHC.co.uk Forums => CB750 => Topic started by: neat street on August 28, 2013, 04:26:25 PM
Title: Drive chain sprocket
Post by: neat street on August 28, 2013, 04:26:25 PM
Hi All
Just started to do an engine strip, it will be slow coz I have other jobs on the go. I have taken a look at the front drive sprocket, and this seems loose but there is no adjustment. should this be a tight fit with no movement? (side to side movement approximately 4mm)
Many thanks for your input.
John
Title: Re: Drive chain sprocket
Post by: mick on August 28, 2013, 04:38:41 PM
Hi john a bit of play is acceptable I think, not sure about 4mm, could be due to pattern sprocket ?, cheers  ;) Mick
Post by: steff750 on August 29, 2013, 12:21:52 AM
 ;) yes same as mick says  no worries a bit of side play is ok just make sure the two securing bolts and locking washer are nipped up tight, even then the sprocket will feel a bit loose  ::)
Post by: neat street on August 29, 2013, 10:44:11 AM
Hi Mick and Steff, thank for your help. I will probably need more advise soon?
Many thanks
John
Post by: mick on August 29, 2013, 11:20:20 AM
No worries John ask away  ;) cheers Mick.
