SOHC.co.uk Forums => CB500/550 => Topic started by: MIKE550/4 on October 28, 2013, 06:55:56 PM
Title: Front mudguard item prices
Post by: MIKE550/4 on October 28, 2013, 06:55:56 PM
not usually one to moan about prices but this seems excessive for such little parts
6 rubber washer mounts  40513310000
6 collars   40514310000
6 bolts   92101-060200A
47 quid delivered ? for basically 6 rubber washers, 6 bolts and 6 collars
is there an alternative ..... hardware shop ?
Title: Re: Front mudguard item prices
Post by: mickwinf on October 28, 2013, 07:57:45 PM
I reckon its these small items which cause the cost of restoration to spiral to a level you never expect. the larger items are easy to estimate but all these little bits add up!
Post by: peterengland on November 08, 2013, 03:52:50 PM
hell, I would just go to the hardware shop, a bolt is a bolt and as long as it does the job, what the hell?
Post by: Bryanj on November 09, 2013, 06:50:25 AM
 A bolt yes but you can't get the top hat washers or special sized grommets at the local hardware shop
Post by: LesterPiglet on November 09, 2013, 02:19:20 PM
Surely the tyre will let go before enough stress is put on those bolts.
Post by: MIKE550/4 on November 09, 2013, 03:56:27 PM
well I forked out in the end, the bolts I could get elsewhere, the top hat washers and grommets I have not seen anything else like this in hardware shops so they had me over a barrel really
