SOHC.co.uk Forums => CB650 => Topic started by: RickyC83 on November 03, 2013, 05:27:15 PM
Title: front brake discks
Post by: RickyC83 on November 03, 2013, 05:27:15 PM
are ther any discks of later modles that have larger discks but will still fit the comstarts on my cb650z 1980
thanks
Title: Re: front brake discks
Post by: matthewmosse on November 03, 2013, 10:51:00 PM
Bigger disks might mean different forks or a complex brackett to convert the calper mount to it's new home / differnt calipers. - you'd need to alter more than just the disks. Have you tried experimenting with better brake pads?
Post by: LesterPiglet on December 01, 2013, 05:23:48 PM
I would have thought the discs on a 650 would be adequate. I get by with one on the 550.
If it's cosmetics why not get them drilled?
Post by: RickyC83 on December 08, 2013, 10:03:10 AM
It was to fit some different callipers which where nearly imps able to position with anuf  disk touching the pad. I decided to restore the original calipers instead (http://img.tapatalk.com/d/13/12/08/eja9y9ad.jpg)(http://img.tapatalk.com/d/13/12/08/a9asa5yr.jpg)
