SOHC.co.uk Forums => CB500/550 => Topic started by: paul G on November 15, 2013, 12:58:20 PM
Title: BREATHER PIPES AND CABLE ROUTING
Post by: paul G on November 15, 2013, 12:58:20 PM
Hi,
                On the breather pipes does the one from the head join to the one from the right angle piece on the air filter box (two pieces).
The one from the  bottom of the air filter box, does it just sit between the engine and swinging arm.
Has anyone got a cable routing diagram for all the cables. I have one for my 400 4 but would like the same for the 550 K3.
Regards,
Title: Re: BREATHER PIPES AND CABLE ROUTING
Post by: peterengland on November 15, 2013, 01:59:39 PM
Yeah the breather from the head goes to the right angle joint and into the air cleaner box, this is really counter- intuitive as you are effectively feeding dirty air to the cleaner, but what the heck, Honda seem to know what they are doing! The other is a drain and just hangs down.
Post by: Bryanj on November 15, 2013, 09:48:40 PM
email me direct to blj@blj.org.uk and  i will scan the page from the build manual for you
