Other Stuff => Tricks & Tips => Topic started by: Johnwebley on November 25, 2013, 04:57:36 PM
Title: Boyer Ignition on the SOHC 4's
Post by: Johnwebley on November 25, 2013, 04:57:36 PM
I have a CB500-4,
 I have had it since about 1977,its an M plate,
 I have fitted Boyer ignition,its proved very good ,and reliable,
but , some thing that has happened twice in the past 25yrs is worth mentioning,
the general instalation is easy,
but over time,check the connection of the 2 wires on the sensor plate,
I have found the small screws that are the connections for the sensor coils becomes loose,giving poor starting and slow speed running,
 hopefully I have cured my issues using lock washers,
will let you know over the next 25 yrs
Title: Re: Boyer Ignition on the SOHC 4's
Post by: Yoshi823 on February 01, 2016, 09:33:12 PM
I replaced the complete points assembly on my CB750F2 back in the late 70s & spotted that where the blue & yellow wires attached to the laminate back plate of the BB ignition that there was apossibilty that they might come loose. So I loctited the connection so that it would never come undone with vibration  ;)
