SOHC.co.uk Forums => CB500/550 => Topic started by: MikeM on January 20, 2014, 01:38:13 PM
Title: refitting this part
Post by: MikeM on January 20, 2014, 01:38:13 PM
Having problems with refitting a part  no 15
currently my no 15 and 12 are joined, as they came off the bike, do they have to be separated to get it back on and be able to slide the spindle through ?
(http://i974.photobucket.com/albums/ae228/INEEDMOREPICS/honda-cb550k3-four-england-kick-arm-pedal_bigma000085f18_6196_zpsc09dc4aa.gif) (http://s974.photobucket.com/user/INEEDMOREPICS/media/honda-cb550k3-four-england-kick-arm-pedal_bigma000085f18_6196_zpsc09dc4aa.gif.html)
Title: Re: refitting this part
Post by: LesterPiglet on January 20, 2014, 02:21:45 PM
I've only done it when they are separated. Don't know if it can be done otherwise.
Post by: MikeM on January 20, 2014, 02:39:05 PM
thanks so if I separate is there still enough room to clear  that bracket on the swingarm ?
Post by: Bryanj on January 20, 2014, 04:35:20 PM
I think you need to fit them before fitting the swing arm mate
Post by: Trigger on January 20, 2014, 04:41:47 PM
Part number 15 should be fitted before the swinging arm. I took one off a couple of days ago, but i was taking the swinging arm off. You could try popping the rear shocks off and see if dropping the swinging arm down will give you enough room. The shocks will have to come off anyway.
Post by: LesterPiglet on January 20, 2014, 06:45:42 PM
Remove the wheel, detach the shocks and push the swinging arm up and you should be able to fit it.
Post by: Bitsa (Ralph Wright - RIP) on January 20, 2014, 07:08:46 PM
Agreed with all
Bitsa
Post by: MikeM on January 21, 2014, 02:00:12 PM
thanks looks like a slight dismantle then........
