SOHC.co.uk Forums => CB500/550 => Topic started by: Trigger on September 10, 2014, 08:22:53 PM
Title: Cable & wiring root CB500
Post by: Trigger on September 10, 2014, 08:22:53 PM
Has anyone got a cable and wiring root diagram for a CB500K (low bars). If you could post a diagram i would be grateful.
Title: Re: Cable & wiring root CB500
Post by: Trigger on September 10, 2014, 11:53:03 PM
No one got one then?
Post by: Lobo on September 11, 2014, 12:16:19 AM
Trig, not familiar with the 500/550 differences... but perhaps you can pick the bones outta these?
Simon
Post by: Trigger on September 11, 2014, 08:29:08 AM
Cheers Simon. Know the 550 inside out but, never built a 500 bike before only the engines. Everything is sorted its the throttle cables that i was trying to work out if went down the right or left side of the frame. Have seen them down the left side and cross over to the right through the hole where the coils sit. Does not look right on this one.
Post by: Bryanj on September 11, 2014, 08:41:44 AM
Just got home from a 15 hour shift, i have the build/pdi sheets and will scan that later mate
Post by: Trigger on September 11, 2014, 08:43:18 AM
Cheers Bryan :)
Post by: mickwinf on September 11, 2014, 09:08:20 AM
Graham I am sure the cables go down the r/h side of the frame on the uk bikes otherwise they pull tight on full lock
Post by: Bryanj on September 11, 2014, 04:32:02 PM
I have had a look and the pdi/set up shows nothing. In the manual it only shows route for the 550 and that is inbetween the clocks, down the LH side (as sat on the bike) and through the big hole where the coils are. Hope that helps
Post by: Trigger on September 11, 2014, 05:01:27 PM
Cheers boy's. I found it strange that i could not find any info on the 500. Found some stuff on the NET site but, all those are for high bars. At the moment i have them down the left side and through the hole. Thanks for looking :)
Post by: s7paul on September 12, 2014, 07:56:18 PM
Definitely down the right hand side as you sit on the bike.  Route them over the front tank mounting.
Post by: Trigger on September 12, 2014, 07:57:36 PM
Cheers Paul, i am trying all options ;)
Post by: matthewmosse on September 12, 2014, 11:13:50 PM
On my 500/4 the wiring wax down the left of the headstock, been like that for many years and miles.
Post by: mickwinf on September 13, 2014, 05:56:30 PM
Trig I have found this pic from the assembly/pdi instructions. It shows the cable route from the front of the bike and you can see the cables go to the rh of the bike as you sit on it, that is the same side as the throttle, hope this helps
Post by: Trigger on September 13, 2014, 06:37:32 PM
Cheers Mick, The bars i have are lower than the ones in the drawing/picture. I can not get the brake hose down between the clocks.
The bar type i have are the same as the KO in this link>>>  http://www.ebay.co.uk/itm/HONDA-CB500-FOUR-1971-MINT-ORIGINAL-CONDITION-2400-MILES-UNRESTORED-/331276440972?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2047675.l2557&nma=true&si=9nI746JaJXMHJumMOU2O9E1f6sg%253D&orig_cvip=true&rt=nc
Sorry, in the last picture.
