SOHC.co.uk Forums => Project Board => Topic started by: martin_uk on November 14, 2014, 01:35:03 PM
Title: CB750F1 Project
Post by: martin_uk on November 14, 2014, 01:35:03 PM
Bought bike from friend who told me the engine was seized from standing and probably needed a light hone and rings!
(https://farm6.staticflickr.com/5094/14016671394_b5fc9400ed_c.jpg) (https://flic.kr/p/nmB75b)2014_0425cb750B40028 (https://flic.kr/p/nmB75b) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
I think it has an early Honda worm drive
(https://farm8.staticflickr.com/7212/14016227185_ab90a1c155_c.jpg) (https://flic.kr/p/nmyQ2p)2014_0425cb750B40025 (https://flic.kr/p/nmyQ2p) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Title: Re: CB750F1 Project
Post by: martin_uk on November 14, 2014, 01:38:29 PM
Head was badly corroded
(https://farm8.staticflickr.com/7370/14013027092_2622dffc1e_c.jpg) (https://flic.kr/p/nmhqKo)2014_0425cb750B40023 (https://flic.kr/p/nmhqKo) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm8.staticflickr.com/7371/13896401270_582ef33fb4_c.jpg) (https://flic.kr/p/naYFXm)2014_0427cb750B40009 (https://flic.kr/p/naYFXm) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Post by: preyno2 on November 14, 2014, 01:39:53 PM
Goodness me!
Where's it been standing, in the garden pond?
Post by: Trigger on November 14, 2014, 01:41:16 PM
The last picture looks like someone is using the wrong tool to clean it up.
Post by: preyno2 on November 14, 2014, 01:46:42 PM
I don't know whether it's badly corroded or part of the piston ring has been bouncing about in the chamber
Post by: martin_uk on November 14, 2014, 01:54:18 PM
Just a rotary wire brush, the metal had corroded so badly .
Post by: Trigger on November 14, 2014, 01:57:51 PM
Can be repaired but, the cost would be sky high. It would need everything.
Post by: martin_uk on November 14, 2014, 02:04:22 PM
Plus the right front engine mount is broken  >:(
(https://farm6.staticflickr.com/5544/13904718278_5db43b9b34_c.jpg) (https://flic.kr/p/nbHjj3)2014_0502cb750B40094 (https://flic.kr/p/nbHjj3) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Post by: Trigger on November 14, 2014, 02:06:40 PM
You have a very nice mate that sold you that.
Post by: martin_uk on November 14, 2014, 02:10:36 PM
Pistons took some shifting!
(https://farm8.staticflickr.com/7077/14045136773_5dfdd674f0_c.jpg) (https://flic.kr/p/np7ZQz)2014_0426cb750B40008 (https://flic.kr/p/np7ZQz) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Diesel soaking
(https://farm3.staticflickr.com/2901/14025535124_18c23d7cc5_c.jpg) (https://flic.kr/p/nnowX7)2014_0426cb750B40001 (https://flic.kr/p/nnowX7) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm3.staticflickr.com/2927/14025127995_8103667550_c.jpg) (https://flic.kr/p/nnmrVD)2014_0426cb750B40010 (https://flic.kr/p/nnmrVD) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Post by: martin_uk on November 14, 2014, 02:13:32 PM
You  can see the engine looked quite corroded
(https://farm8.staticflickr.com/7313/14036290593_a4f493ab02_c.jpg) (https://flic.kr/p/nokEbe)2014_0417cb750B40017 (https://flic.kr/p/nokEbe) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Post by: matthewmosse on November 14, 2014, 02:41:06 PM
I had a cb550 head that had similar dammage. In my case a previous owner had broken all the top rings, several of which had smashed out of the top of the pistonand scratched and dented the head up something chronic. They had obviously been in there, removed most of the debris, sealed up again re using old gaskets and leaving bits of broken ring in the sump and blue gaskett goo behind as a calling card. I bought thd bike taxed and tested, rode it a bit and found it was ok to ride but if stalled when hot it wouldn't restart until cold. It also leaked oil, but it wax also cheap. I only found the dammage when deciding the oil leak should really be fixed. I bunged on a decent set of barrels and pistons from a scrap engine, and re used the well scarred head. It ran for years like that, never down on power or hard to start after replacing the wrecked pistons. It eventually dropped a valve, many years later. Still have the remains somewhere.
Post by: UK Pete on November 14, 2014, 04:17:22 PM
Blooming heck fella that engine is a very bad starting point,
pete
Post by: cb ghia on November 14, 2014, 05:44:39 PM
What in the hell is that thing?  Is that a worm?  You must have very different worms on your side of the pond.
Post by: Spitfire on November 14, 2014, 07:33:06 PM
Unbelievable, poor bike.
Post by: mick on November 14, 2014, 09:31:36 PM
it looks like grease out of a grease gun , think the engines fit for a boat anchor  ;) cheers mick.
Post by: LesterPiglet on November 14, 2014, 09:41:20 PM
That head damage wasn't caused by rings as it extends beyond the bore. My guess is it was caused by a twat.
Post by: martin_uk on November 14, 2014, 11:06:43 PM
Just the effect of water in combustion chamber over an extended period of time.
Post by: martin_uk on November 14, 2014, 11:08:08 PM
I think that someone thought that squirting grease in there would help to un seize ::)
Post by: matthewmosse on November 15, 2014, 07:59:48 AM
on mine, the rings had smashed their way out of the top of the piston somehow and gotten trapped between the piston and head causing similar dammage, then someone had poped the head off, removed the debris. I went one further and replaced the pisteons but ran a head with very similar dammage. Water doesn't do that to a head, I had an engine where all the cultch casing had literally corroded away, gearbox totally shot, somehow the head was immaculate once a few kilos of thick clay mud were removed from inside the rocker cover. I still think it sensible to source a replacement engine though I have thashed a few years commuting out of 550s with parts that rough.
Post by: UK Pete on November 15, 2014, 12:49:36 PM
Ok martin here are the pictures as promised , the engine seems to be complete, but is totally stripped, this is how i bought it, it was stripped as it needs reconditioning, probably rebore and the usual things like cam chain and tensioners etc
Some of the outer covers are no good , the altenator cover has damage, and the sump plug hole has been welded up
The F1 exhaust is about as good as you will find for a second hand one, very solid , the side that you see is still quite bright but far from perfect, the rear where it does not get cleaned has fine surface corrosion but solid no holes , tiny crack where it clamps up, but very usable
Here is the link to the pictures the price is £300 for the lot
http://s924.photobucket.com/user/UK-Pete/library/392%20engine%20and%20%20F1%20exhaust
Post by: martin_uk on November 15, 2014, 02:42:35 PM
Thanks Pete, really appreciate your help.
I can collect today if you are available, will call to arrange.
Can I make a final decision on silencer when I see.
Thanks again.
Post by: martin_uk on November 16, 2014, 04:42:59 PM
Thanks to Pete, now have another engine to play with :D
Post by: martin_uk on November 16, 2014, 04:47:32 PM
Here is the bike as I received it.
(https://farm8.staticflickr.com/7429/13993066706_582e25f786_c.jpg) (https://flic.kr/p/njw8dN)2014_0418cb750B40003 (https://flic.kr/p/njw8dN) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Doesnt look too bad, but I wanted to get rid of all the rust, so completely stripped
Post by: martin_uk on November 16, 2014, 04:50:08 PM
Carbs are pretty grungy
(https://farm3.staticflickr.com/2930/14036195203_5e9559b21a_c.jpg) (https://flic.kr/p/nokaPz)2014_0420cb750B40005 (https://flic.kr/p/nokaPz) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm3.staticflickr.com/2927/14013008361_2fe236eef7_c.jpg) (https://flic.kr/p/nmhkbr)2014_0420cb750B40001 (https://flic.kr/p/nmhkbr) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Post by: martin_uk on November 16, 2014, 04:55:50 PM
I wont have to use this engine after all :o
(https://farm6.staticflickr.com/5285/13622147803_a0f04a512d_c.jpg) (https://flic.kr/p/mKK4Xi)2014_0404BM0012 (https://flic.kr/p/mKK4Xi) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Post by: Trigger on November 16, 2014, 04:59:53 PM
Not a bad looking bike. Those carbs will clean up.
Have a rear brake peddle for one of those on fleabay.
Post by: SteveD CB500K0 on November 16, 2014, 05:51:28 PM
Keep it yellow. I do like that colour on the F1.
Post by: Trigger on November 16, 2014, 06:37:26 PM
I am with you on this one Steve. Yellow is the best colour on the F1.
Post by: UK Pete on November 16, 2014, 06:44:27 PM
Great to meet you martin , hope the bits are useful , btw looks like trigger also has the rear master cylinder your after on ebay
Oh yes yellow is really nice on the f1, does anyone know if the f1 is Sulpher Yellow, or parakeet yellow?
pete
Post by: SteveD CB500K0 on November 16, 2014, 06:54:55 PM
Sulphur.
My room-mate at uni had one in 1977.
I'm sure the 400/4 was Parakeet.
Post by: Trigger on November 16, 2014, 06:59:06 PM
Yep, Parakeet 400Four.
Post by: martin_uk on November 16, 2014, 11:06:16 PM
Here is the tank after painting
(https://farm4.staticflickr.com/3744/14279258703_ab9828f40e_o.jpg) (https://flic.kr/p/nKNW8z)tank with decals004 (https://flic.kr/p/nKNW8z) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Post by: martin_uk on November 16, 2014, 11:08:39 PM
and before with hidden rust
(https://farm8.staticflickr.com/7372/14079444881_a664c16872.jpg) (https://flic.kr/p/ns9QrF)2014_0430cb750B40027 (https://flic.kr/p/ns9QrF) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Post by: UK Pete on November 16, 2014, 11:12:10 PM
Tank looks nice , infacty the more i see the yellow the more i like it
pete
Post by: martin_uk on November 17, 2014, 01:00:17 PM
This is a VW colour, as no current code for Sulphur yellow which is slightly lighter.
Post by: Bitsa (Ralph Wright - RIP) on November 17, 2014, 03:52:42 PM
Nice tank
Love it
Bitsa
Post by: Trigger on November 17, 2014, 06:46:52 PM
No colour codes for any of these old bikes but, RS paints do sulphur yellow.
Post by: Bitsa (Ralph Wright - RIP) on November 17, 2014, 07:20:25 PM
They look good dont they take a look at this one
http://www.leboncoin.fr/motos/734222790.htm?ca=20_s
Bitsa
Post by: martin_uk on November 17, 2014, 07:34:46 PM
pete
I have fancied a yellow bike for a while.
Post by: martin_uk on November 17, 2014, 08:08:04 PM
Chain guard pretty rusty
(https://farm6.staticflickr.com/5590/14676176854_905880261b_c.jpg) (https://flic.kr/p/omTf4Y)2014_0507cb750B40011 (https://flic.kr/p/omTf4Y) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Wheels are OK, but rusty patches and rusty spokes.
(https://farm8.staticflickr.com/7393/13971910188_4945563b39_c.jpg) (https://flic.kr/p/nhDG8f)2014_0507cb750B40004 (https://flic.kr/p/nhDG8f) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Decided to get new DID rims and repro spokes from DS and have a go at rebuilding myself ;D
Post by: Bitsa (Ralph Wright - RIP) on November 17, 2014, 08:09:51 PM
Go for it mate diamond geezer
Bitsa
Post by: martin_uk on November 17, 2014, 08:24:57 PM
First wheel took about 3 hrs to lace up, whilst I got the hang of it.
(https://farm8.staticflickr.com/7339/14155216951_5b94de1fb4_c.jpg) (https://flic.kr/p/nyRbQF)2014_0507cb750B40031 (https://flic.kr/p/nyRbQF) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
second took about an hour
(https://farm8.staticflickr.com/7351/14158532685_f09a451d69_c.jpg) (https://flic.kr/p/nz9buv)2014_0507cb750B40033 (https://flic.kr/p/nz9buv) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Now I need to true
Used a paddock stand with wheel balancer adaptor.
Pencils were used as ref point  to true by eye.
Took a while and used tone of spoke when tapped as a guide to tension.
Dont forget to measure offset before you strip the wheels :-[
Glad I did it as have never tried before, quite satisfying  8)
(https://farm4.staticflickr.com/3737/14087498368_9abd71a8d4_c.jpg) (https://flic.kr/p/nsS7sU)trueing jig7 (https://flic.kr/p/nsS7sU) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm3.staticflickr.com/2919/14273717534_5607bf1028_c.jpg) (https://flic.kr/p/nKjwWb)trueing jig6 (https://flic.kr/p/nKjwWb) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm3.staticflickr.com/2939/14273718464_f529a1eb73_c.jpg) (https://flic.kr/p/nKjxdd)trueing jig4 (https://flic.kr/p/nKjxdd) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm4.staticflickr.com/3668/14274164265_d196eca66b_c.jpg) (https://flic.kr/p/nKmPJr)trueing jig3 (https://flic.kr/p/nKmPJr) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
I used the inside part of flange and ignored the join when adjusting 'hop'
(https://farm3.staticflickr.com/2896/14273722404_bf1b7d9ac6_c.jpg) (https://flic.kr/p/nKjyo9)2014_0526eng0011 (https://flic.kr/p/nKjyo9) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Post by: UK Pete on November 17, 2014, 08:30:08 PM
I am watching and learning i have 4 wheels to do when i get enough money saved up to rechrome the rims
Nice work there Martin
pete
Post by: Bitsa (Ralph Wright - RIP) on November 17, 2014, 09:03:37 PM
Plus one with Pete
Damn good job
BITSA
Post by: martin_uk on November 17, 2014, 09:50:30 PM
pete
Thanks, now if only a could find a new exhaust  :'(
Post by: Rozabikes Tim on November 17, 2014, 10:29:50 PM
Excellent work, as the others say "learning" from your post.
Where did you source the wheel balancing adapter for paddock stand, or was it an adapted adapter!
Tim
Post by: Green1 on November 18, 2014, 05:48:45 PM
I'm watching but I don't think its going in.  ::)
But one thing I do know is the F1 looks best in yellow.
Mick
Post by: martin_uk on November 18, 2014, 08:42:20 PM
Tim
I bought on Ebay, there are a few on there.
http://www.ebay.co.uk/itm/Portable-Wheel-Balancer-Paddock-Stand-Bike-Motorcycle-Motorbike-Track-Day-Kit-/131209234829?pt=LH_DefaultDomain_3&hash=item1e8cae098d (http://www.ebay.co.uk/itm/Portable-Wheel-Balancer-Paddock-Stand-Bike-Motorcycle-Motorbike-Track-Day-Kit-/131209234829?pt=LH_DefaultDomain_3&hash=item1e8cae098d)
Post by: martin_uk on November 18, 2014, 08:44:14 PM
It is painted in VW L10A RALLYGELB, DS transfers and then clear coat. Wasnt done by me  ;D
Post by: martin_uk on November 18, 2014, 09:32:10 PM
Frame stripped ready for blast and powder cost.
(https://farm8.staticflickr.com/7399/14091081785_1b6a6752de_c.jpg) (https://flic.kr/p/ntbtFX)2014_0502cb750B40053 (https://flic.kr/p/ntbtFX) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm8.staticflickr.com/7347/13904477847_43116ff07b_c.jpg) (https://flic.kr/p/nbG5QF)2014_0502cb750B40057 (https://flic.kr/p/nbG5QF) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
modified rh engine mounting before and after- makes it easier to fit engine as doesnt catch.
(https://farm8.staticflickr.com/7187/13904486000_26621f92df_c.jpg) (https://flic.kr/p/nbG8gf)2014_0502cb750B40041 (https://flic.kr/p/nbG8gf) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm3.staticflickr.com/2913/14087953072_183705c1c7_c.jpg) (https://flic.kr/p/nsUrCC)2014_0502cb750B40049 (https://flic.kr/p/nsUrCC) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
back from powder coat
(https://farm3.staticflickr.com/2921/14256943752_5e9343fbca_c.jpg) (https://flic.kr/p/nHQyF3)2014_0519eng0017 (https://flic.kr/p/nHQyF3) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Post by: UK Pete on November 18, 2014, 10:16:55 PM
Is that an import frame martin, way too clean for a UK one,
nothing better than a freshly coated frame
pete
Post by: martin_uk on November 18, 2014, 10:23:55 PM
pete
Its Uk, but picture looks better than reality, as lots of rusty areas but nothing too bad.
Nice to start with a fresh frame even if it takes ages to clean out all the threads ;D
Post by: Spitfire on November 22, 2014, 08:59:11 AM
I remember when my frame looked like that, I was too scared to touch it !
Post by: martin_uk on November 28, 2014, 05:21:53 PM
Rear wheel and brakes installed.
Original caliper powder coated, found the brake pad cover on CSMNL
(https://farm4.staticflickr.com/3872/14483292729_25be4eee33_c.jpg) (https://flic.kr/p/o4QEkB)2014_0716brakes0020 (https://flic.kr/p/o4QEkB) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
You can also see the braided stainless brake hose with black cover I used as could not get OE
Post by: martin_uk on November 28, 2014, 05:23:17 PM
Sprocket side
(https://farm4.staticflickr.com/3888/14666743871_788d0c75ae_c.jpg) (https://flic.kr/p/om3TYk)2014_0716brakes0019 (https://flic.kr/p/om3TYk) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Post by: martin_uk on November 28, 2014, 05:25:35 PM
Detail of front brake hose (from DS)
New front mudguard from CSMNL
(https://farm4.staticflickr.com/3892/14669937575_0865d046ed_c.jpg) (https://flic.kr/p/omkgmc)2014_0716brakes0005 (https://flic.kr/p/omkgmc) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Post by: martin_uk on November 28, 2014, 05:34:59 PM
Front caliper, might have to change the bolt :-[
(https://farm6.staticflickr.com/5526/14483297178_df4f2a4e39_c.jpg) (https://flic.kr/p/o4QFEj)2014_0716brakes0004 (https://flic.kr/p/o4QFEj) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Anyone know which way round indicator buzzer should go?
(https://farm3.staticflickr.com/2898/14483439098_8422b01893_c.jpg) (https://flic.kr/p/o4RpRd)2014_0716brakes0009 (https://flic.kr/p/o4RpRd) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Resprayed instruments in Simoniz Satin Black, quite fiddly cleaning off rust and masking without stripping.
(https://farm4.staticflickr.com/3837/14667767564_126110ff2d_c.jpg) (https://flic.kr/p/om99hd)2014_0716brakes0031 (https://flic.kr/p/om99hd) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Gauge colours vary.
(https://farm3.staticflickr.com/2925/14669758652_24bdbf555f_c.jpg) (https://flic.kr/p/omjmaj)2014_0716brakes0033 (https://flic.kr/p/omjmaj) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
I used a DS front master cylinder.
(https://farm4.staticflickr.com/3925/14689980563_8a3db7012f_c.jpg) (https://flic.kr/p/oo6ZqX)2014_0716brakes0034 (https://flic.kr/p/oo6ZqX) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Post by: martin_uk on November 28, 2014, 05:38:25 PM
Here is the before on rear caliper
(https://farm9.staticflickr.com/8661/15822556925_da3b59d1c2_c.jpg) (https://flic.kr/p/q7bJVB)2014_0418cb750B40087 (https://flic.kr/p/q7bJVB) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Post by: UK Pete on November 28, 2014, 06:01:36 PM
Great pictures martin , loving your work , keep it coming
pete
Post by: Bitsa (Ralph Wright - RIP) on November 28, 2014, 06:42:40 PM
Plus one with Pete bloody good.
I have the same problem with my clocks green backs slightly different
Bitsa
Post by: Trigger on November 28, 2014, 07:10:57 PM
Bitsa
I have always wondered why they do that. Have seen this on CB550's also.
Post by: martin_uk on November 29, 2014, 11:16:06 AM
Engine ready to reassemble
(https://farm4.staticflickr.com/3878/14881526556_1892957be0_c.jpg) (https://flic.kr/p/oF2Ho5)eng inst 110814028 (https://flic.kr/p/oF2Ho5) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm4.staticflickr.com/3840/14904161502_1812daf307_c.jpg) (https://flic.kr/p/oH2HXL)eng inst 110814027 (https://flic.kr/p/oH2HXL) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
and assembled
(https://farm6.staticflickr.com/5593/14717918428_12dc85b46b_c.jpg) (https://flic.kr/p/oqzboh)eng inst 110814009 (https://flic.kr/p/oqzboh) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm4.staticflickr.com/3897/14717829990_164e70d492_c.jpg) (https://flic.kr/p/oqyJ6u)eng inst 110814008 (https://flic.kr/p/oqyJ6u) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Post by: martin_uk on November 29, 2014, 11:27:45 AM
Engine going back in.
I decided to install minus covers, sump and exhaust studs to make it a bit easier.
Used a U section bar I had under cam chain tensioner with ratchet straps to secure, plus lots of padding and protection.
(https://farm6.staticflickr.com/5556/14881521136_c9447ab05d_c.jpg) (https://flic.kr/p/oF2FLC)eng inst 110814019 (https://flic.kr/p/oF2FLC) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm4.staticflickr.com/3903/14717845690_3f2b2943c0_c.jpg) (https://flic.kr/p/oqyNLb)eng inst 110814018 (https://flic.kr/p/oqyNLb) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm4.staticflickr.com/3857/14717885769_a91ba7c0a4_c.jpg) (https://flic.kr/p/oqz1Fc)eng inst 110814017 (https://flic.kr/p/oqz1Fc) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm6.staticflickr.com/5587/14717962867_5c275c8e92_c.jpg) (https://flic.kr/p/oqzpAt)eng inst 110814016 (https://flic.kr/p/oqzpAt) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm6.staticflickr.com/5578/14881519166_c6b787b70e_c.jpg) (https://flic.kr/p/oF2FbE)eng inst 110814014 (https://flic.kr/p/oF2FbE) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Frame prepared
(https://farm4.staticflickr.com/3904/14881518246_bcfd12b962_c.jpg) (https://flic.kr/p/oF2EUN)eng inst 110814012 (https://flic.kr/p/oF2EUN) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Used a split waste pipe to give extra protection to frame.
(https://farm4.staticflickr.com/3898/14717917458_28a97e4c8f_c.jpg) (https://flic.kr/p/oqzb6y)eng inst 110814011 (https://flic.kr/p/oqzb6y) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Tools ready
(https://farm4.staticflickr.com/3921/14717830990_ceb5556a59_c.jpg) (https://flic.kr/p/oqyJoJ)eng inst 110814010 (https://flic.kr/p/oqyJoJ) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Post by: martin_uk on November 29, 2014, 11:35:27 AM
Its in  :)
(https://farm4.staticflickr.com/3853/14901448351_8b3ec2fc28_c.jpg) (https://flic.kr/p/oGMPri)eng inst 110814023 (https://flic.kr/p/oGMPri) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm6.staticflickr.com/5562/14904163892_879f35d315_c.jpg) (https://flic.kr/p/oH2JEY)eng inst 110814024 (https://flic.kr/p/oH2JEY) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm4.staticflickr.com/3912/14717881539_ffd076dd43_c.jpg) (https://flic.kr/p/oqyZqg)eng inst 110814025 (https://flic.kr/p/oqyZqg) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Post by: Bitsa (Ralph Wright - RIP) on November 29, 2014, 02:07:40 PM
Looking really nice well done
Bitsa
Post by: UK Pete on November 29, 2014, 02:25:05 PM
Superb work i love watching other peoples progress
pete
Post by: Green1 on November 29, 2014, 07:51:27 PM
Very smart
Looks like you will have it done for Christmas
Mick
Post by: Bitsa (Ralph Wright - RIP) on November 29, 2014, 08:42:09 PM
Beginning to sway with the painted look even thuough I like some bits of my bikes to look a bit like there age.Got to say they do look damn good maybe next time will consider it
Carry on bloody good
Bitsa
Post by: martin_uk on November 29, 2014, 10:10:14 PM
Thanks for all the positive comments and encouragement.
Anyone who has tried a full rebuild/restore will know the highs and lows, but particularly the sense of satisfaction in bringing bikes back to life.
I often ponder whether to just go for function or as close to original new look.
I decided to keep the original seat cover as it was so good, but did powder coat the base as quite rusty.
(https://farm8.staticflickr.com/7475/15721057980_bc89e74a15_c.jpg) (https://flic.kr/p/pXdwPN)2014_0621eng0057 (https://flic.kr/p/pXdwPN) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm8.staticflickr.com/7546/15721083350_699e063632_c.jpg) (https://flic.kr/p/pXdEnd)2014_0428cb750B40038 (https://flic.kr/p/pXdEnd) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
New clips and pc hinge.
(https://farm4.staticflickr.com/3870/14491847070_2e8db9085c_c.jpg) (https://flic.kr/p/o5Avff)2014_0627clips0017 (https://flic.kr/p/o5Avff) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
I do love getting bits back from platers and powder coaters :D
Post by: Liam on November 29, 2014, 10:17:32 PM
Lovely job fella…  Good effort!
Roll on summer….
Post by: martin_uk on November 29, 2014, 10:18:41 PM
Oh and to make sure I dont run out of things to do, I bought another 2 F1 projects :-[
(https://farm9.staticflickr.com/8609/15907711242_cfdfc6a63a.jpg) (https://flic.kr/p/qeHbku)Ebay purchaseno2$_1 (https://flic.kr/p/qeHbku) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm9.staticflickr.com/8620/15286101754_8686bed6c3.jpg) (https://flic.kr/p/phMguw)Ebay purchase$_2 (https://flic.kr/p/phMguw) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Post by: martin_uk on December 03, 2014, 09:04:59 PM
Bought an air filter housing assembly on Ebay and found this inside.
(https://farm8.staticflickr.com/7498/15914604246_b774d9acc3_c.jpg) (https://flic.kr/p/qfjvoo)mouse chewed af 183 (2) (https://flic.kr/p/qfjvoo) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Looks like a mouse had been chewing on it  :o
I guess it thought a CB750 air filter housing was an ideal place to raise its kids :)
Post by: martin_uk on December 05, 2014, 07:49:35 PM
Just picked up tank, seat cowl  and side panels from No.2 bike after getting painted.
Decided to get done in Toyota Orange Twist 4W5 its the colour used on new Aygo Excite and is a 3 stage pearl finish.
Looks like plain Orange but with a fine metallic finish which lights up in sunshine 8)
I havnt yet decided whether to fit tank decals or not.
I also have had a filler cover done in gloss black.
I will gets some pics up, but looks lovely ;D
Post by: martin_uk on December 05, 2014, 08:22:46 PM
pics as promised
(https://farm8.staticflickr.com/7527/15768525707_326c1306d0_c.jpg) (https://flic.kr/p/q2pPjT)2014_1205fparts0013 (https://flic.kr/p/q2pPjT) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm8.staticflickr.com/7577/15952296391_1df8113e08_c.jpg) (https://flic.kr/p/qiDFWX)2014_1205fparts0015 (https://flic.kr/p/qiDFWX) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm8.staticflickr.com/7479/15928460426_6bb8003279_c.jpg) (https://flic.kr/p/qgxwm3)2014_1205fparts0010 (https://flic.kr/p/qgxwm3) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm9.staticflickr.com/8572/15768519747_3610c08de2_c.jpg) (https://flic.kr/p/q2pMy8)2014_1205fparts0007 (https://flic.kr/p/q2pMy8) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
My inspiration was the Rickman CR750 and Laverda Jota Orange.
Post by: UK Pete on December 06, 2014, 10:01:21 AM
Looks nice martin, who does your paintwork?
pete
Post by: martin_uk on December 06, 2014, 07:43:56 PM
pete
Its a co that I have used at work, but does not do retail work, did more as a favour ::)
Post by: martin_uk on December 08, 2014, 05:32:49 PM
F1 completed pics  :D
(https://farm9.staticflickr.com/8636/15974952561_b90e5d49e3_c.jpg) (https://flic.kr/p/qkDNQz)2014_1208Kparts50012 (https://flic.kr/p/qkDNQz) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm8.staticflickr.com/7461/15976276232_e588e1942f_c.jpg) (https://flic.kr/p/qkLAju)2014_1208Kparts50036 (https://flic.kr/p/qkLAju) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm9.staticflickr.com/8676/15789655390_2f8e94719f_c.jpg) (https://flic.kr/p/q4h7rL)2014_1208Kparts50035 (https://flic.kr/p/q4h7rL) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm8.staticflickr.com/7518/15791222817_131837786c_c.jpg) (https://flic.kr/p/q4q9on)2014_1208Kparts50038 (https://flic.kr/p/q4q9on) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm9.staticflickr.com/8585/15791198597_9200969cf5_c.jpg) (https://flic.kr/p/q4q2bM)2014_1208Kparts50039 (https://flic.kr/p/q4q2bM) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm8.staticflickr.com/7576/15354660174_8c2c343441_c.jpg) (https://flic.kr/p/poQDwf)2014_1208Kparts50007 (https://flic.kr/p/poQDwf) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Post by: Bitsa (Ralph Wright - RIP) on December 08, 2014, 06:49:20 PM
Nice job Martin looks real good
Bitsa
Post by: martin_uk on December 08, 2014, 07:05:46 PM
Just a few minor details to finish, still looking for that NOS exhaust  ;)
Post by: Spitfire on December 08, 2014, 07:31:09 PM
That looks great, pity about the snow falling on it !
Den
Post by: preyno2 on December 08, 2014, 08:04:24 PM
Great job Martin, well done mate.
Post by: UK Pete on December 08, 2014, 10:00:47 PM
That looks really good martin, didn't seem to take you long to do, is the k8 next
pete
Post by: Trigger on December 09, 2014, 08:34:40 AM
He is quicker than me Pete. I takes me a couple of months to find all the parts.
Post by: JamesH on December 09, 2014, 09:50:58 AM
Jesus you don't hang about Martin - great job, looks lovely.
Post by: martin_uk on December 09, 2014, 04:44:53 PM
Well it is a temporary engine that came from second f1 project, still have to sort out the crank case with broken engine mount :-\
(https://farm4.staticflickr.com/3747/14279267333_8101dc84ce_c.jpg) (https://flic.kr/p/nKNYGn)2014_0519eng0024 (https://flic.kr/p/nKNYGn) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
Post by: martin_uk on December 09, 2014, 04:50:06 PM
Thanks for all positive comments, I do like the result, but cost far more to do than generally achieved for this model  :-[
Still it wasnt done for profit ;D
Should be finished on K8 by new year.......... ;) Now where is that Sandcast project ::)
Post by: Trigger on December 09, 2014, 05:00:36 PM
Martin, you seem to have too much time on your hands. What is your address and i will send a couple of trucks full of bikes and parts to keep you busy.
Post by: martin_uk on December 09, 2014, 05:40:40 PM
When I get going I have been known to still be working at 3am in morning :-[
Post by: Bitsa (Ralph Wright - RIP) on December 09, 2014, 07:07:28 PM
Wow thats dedication for you ;) ;)
Bitsa
