Other Stuff => Misc / Open => Topic started by: mihai.i on November 18, 2014, 06:06:16 PM
Title: XADO Revitalizant EX 120???
Post by: mihai.i on November 18, 2014, 06:06:16 PM
Hi guys!
I just saw on local forum in Romania a product called XADO Revitalizant EX 120, that they say is really good for your engine  :-\, restores worn surface of engine cylinders, eliminates microcracks and scratches, increases and levels compression in cylinders and other stuff like this...
quote
„Restores worn surface of engine cylinders, eliminates microcracks and scratches
Increases and levels compression in cylinders
Protects friction surfaces against wear
Reduces fuel consumption considerably
Restores engine capacity up to factory values
Increases service life of an engine by 3 times
Decreases the level of toxic components in exhaust gases
Decreases noise and vibration level
More details here: http://xado.us/revitalizants/ex120/revitalizant-ex120-motor-equipment
What is about this product?
Do you even hear of it?
Title: Re: XADO Revitalizant EX 120???
Post by: JamesH on November 18, 2014, 06:34:55 PM
Its a scam. Avoid.
Post by: Trigger on November 18, 2014, 06:44:14 PM
Never believe everything you read. "Restores engine up to factory values" What the hell does that mean and "Restores worn surface of engine  cylinders". well, that is me out of business then. :'( :'( :'( :'(
Hold on i cross hatch the cylinders and this stuff is going to correct that Hahahaha
Post by: Bitsa (Ralph Wright - RIP) on November 18, 2014, 06:46:43 PM
Trig
Must be an ali welder inside the tin yeah right
Remember oil stop?never stopped jack
Bitsa
Post by: Trigger on November 18, 2014, 06:52:35 PM
Bitsa, i have ordered 200 tubes and a new armchair but, i think i will get some funny looks when i hand over the bill ;D
Post by: Bitsa (Ralph Wright - RIP) on November 18, 2014, 06:53:34 PM
 ;D ;D ;D ;D ;D
Brill Mate
Bitsa
Post by: matthewmosse on November 18, 2014, 07:40:00 PM
Snake oil. It is claiming the inpossible therefore probably delivers nothing, might even do harm. To live up to its claims it would need to weld steel to extreme accurate tolerance, alloy, ditto and know where to and not to stick. Suppose it got confused and welded the oil restrictors completely shut and oil starved the top end.
Post by: K2-K6 on November 19, 2014, 10:26:14 PM
What's in the tin? a new engine?
Post by: Lynx on November 26, 2014, 09:30:56 AM
It@s probably just like that STP stuff. Just thickens the oil. Of course you could just put 20w50 in.
Post by: hairygit on November 26, 2014, 09:40:10 AM
If it's like that STP oil treatment, your engine will seem better, but you won't be getting far, ruins wet clutches, slip like crazy! A mate put some in a 400/4 many years ago, and even changing the oil and new clutch plates it still happened. In the end he had to strip the engine and wash the cases and all internals in parrafin before the problem was solved. :o
Post by: Bitsa (Ralph Wright - RIP) on November 26, 2014, 01:40:18 PM
Got a tin of wynns if any body wants it
CRAP STUFF STOPS OIL LEAKS IN YER DREAMS
Bitsa
Post by: RGP750 on November 26, 2014, 05:01:14 PM
Hey you didn't get that to put into number 2 did you  ;D ;D ;D (oops! banter)
