SOHC.co.uk Forums => CB750 => Topic started by: NigelWilmshurst on January 27, 2015, 05:45:11 PM
Title: Unknown petrol tank, please help
Post by: NigelWilmshurst on January 27, 2015, 05:45:11 PM
Hi, I have just joined the club, I have an aluminium petrol tank made for a Honda CB 750, I bought it about 20 years ago second hand, it looks different to the Seeley & Britain tanks, can anybody tell me anything about it? I have added a picture today 27/01/15 Bare aluminium F1 Café racer.
Nigel
Title: Re: Unknown petrol tank, please help
Post by: royhall on January 27, 2015, 06:19:29 PM
Blimey Nigel, where dya park that? In the sea. ;D ;D
Post by: NigelWilmshurst on January 27, 2015, 07:10:12 PM
It was buried at the back of my workshop for about 5 years, nothing a good clean and some petrol won't sort out!
Post by: ka-ja on January 27, 2015, 07:13:37 PM
Hi,
   A bit past autosol then ;D ;D ;D
Post by: NigelWilmshurst on January 27, 2015, 07:22:41 PM
I will get a new battery and fire it up, it always starts even when left over a year, time to strip it and get riding again, anyone know where I can get the wheels respoked and rims chromed...
Post by: Trigger on January 27, 2015, 07:25:29 PM
Cheaper to buy new rims and where are you located ?
Post by: NigelWilmshurst on January 27, 2015, 07:28:42 PM
New rims then, I'm in Heathfield, East Sussex
Post by: NigelWilmshurst on January 27, 2015, 07:30:36 PM
Any ideas on the petrol tank origin?
Post by: Trigger on January 27, 2015, 07:33:03 PM
Never seen one like that before. Could be a one off.
Post by: NigelWilmshurst on January 27, 2015, 07:37:46 PM
I filled it up to the top once, pulled out the garage and the bike was so top heavy it fell over, never again its a massive tank
Post by: Nurse Julie on January 27, 2015, 08:32:29 PM
Are you the Nigrl that does the plating and polishing, up behind Groombridges ?
Post by: Trigger on January 27, 2015, 08:44:41 PM
Your in trouble now Nigel  ;D ;D ;D
Post by: Nurse Julie on January 27, 2015, 08:52:50 PM
 ;D ;D ;D No he's not, I'm just being nosey
Post by: Trigger on January 27, 2015, 09:14:56 PM
Well, save's me a load of hassle if it stops you from tinkering  ;D ;D ;D
Post by: Nurse Julie on January 27, 2015, 09:31:39 PM
It's not me tinkering you need to worry about Trig, it's when I've put it all back together and got loads of bits left over, that when you need to start panicking  ::) ::) ::)
Post by: Trigger on January 27, 2015, 09:38:40 PM
You did not work for British Rail in the past. Took on a British Rail engineer some years ago. He built a engine and said, "look what i have saved". Looking at a load of parts still on the bench. He only lasted the day.
Post by: dieffe on January 27, 2015, 09:47:51 PM
Nigel
I'm new here too and for some reason I can't see any picture of the tank. Am I doing something wrong?
Post by: Nurse Julie on January 27, 2015, 09:49:44 PM
Nigel posted it in the Gallery
Post by: royhall on January 27, 2015, 09:54:08 PM
Nigel
Whats the external oil feed for (if that's what it is) on the right of the bike?
Cheers Roy
Post by: dieffe on January 27, 2015, 10:29:13 PM
Ah, I see now.
Would this make it easier.  :)
(http://img.photobucket.com/albums/v161/dieffe123/Bikes/Nigelsbike_zpse7c1747f.jpg)
Post by: AshimotoK0 on January 27, 2015, 11:13:21 PM
Careful what you say there Graham,.. they can't all be like that. A British Rail Engineer restored  one of the 1st batch of UK Jan '70 CB750K0's and it has got to be one of the best restorations around !
Ash
Post by: Trigger on January 27, 2015, 11:15:59 PM
Ash
Was not the same guy then ;D
Post by: royhall on January 28, 2015, 07:21:50 AM
Nigel
Cheers Roy
Any ideas on the oil feed, curiosity has got me now. You can just see it on the right hand oil gallery blanking plug?
Post by: NigelWilmshurst on January 28, 2015, 09:19:41 AM
Hi nosey Julie, no I'm not the chroming man behind Groombridge's, I'm a sandblaster, any idea where my petrol tank comes from... have you ever heard of a Honda 750 F1 Sabre, just spotted it scribed into the underneath of the tank!
Post by: SteveD CB500K0 on January 28, 2015, 09:34:23 AM
The Sabre was a VF750
(http://www.motorcyclespecs.co.za/Gallery/Honda%20VF750%20Sabre%2082%20%201.jpg)
Post by: NigelWilmshurst on January 28, 2015, 10:18:08 AM
The tank may of been a 1 off, the external oil feed was my work, after knocking out 3 camshafts in 7000 miles, the feed is taken from the oil gallery that splits the pressure between the top & bottom end, banjo bolt with a flow adjuster, that splits into 2 then 4 pipes, drill and tap into rocker cover, brazed copper pipe then feeds oil directly onto the 4 upper cam carriers, never had a cam go since, its also got an American performance parts big bore kit on it, likes being the other side of the red line
Post by: SteveD CB500K0 on January 28, 2015, 01:04:14 PM
If you Google "Honda Sabre Racer" you can see some people have cafe'd the VF750 - maybe this was one of theirs?
Post by: NigelWilmshurst on January 28, 2015, 01:47:22 PM
Looks quite possible Steve, thanks for your help and what a brilliant forum, I take it David Silver is my best bet to get spares...
Post by: JamesH on January 28, 2015, 06:20:56 PM
Dss or cmsnl.com
Post by: NigelWilmshurst on January 29, 2015, 11:52:55 AM
Thanks Jamesh, time to spend some of my hard earnt money
Post by: Trigger on January 29, 2015, 07:59:32 PM
Not sure if it the angle of the picture but it looks very near a Laverda tank. Is the fuel cap a screw type ?
Post by: NigelWilmshurst on February 02, 2015, 03:25:45 PM
Its a push button cap, Honda 750 Sabre inscribed underneath?
Post by: NigelWilmshurst on February 02, 2015, 03:27:28 PM
Honda 750 F1 Sabre inscribed underneath, its huge!
