SOHC.co.uk Forums => CB750 => Topic started by: El__burro on February 04, 2015, 07:57:50 PM
Ooooooh yeah! ;D
After many kicks the oil pressure light went off.
Then the magic happened.
Just wanted to share with you the first time it roared and what a ROAR.
For sure it needs some adjustments to be fully satisfied but my ambition was to start the engine and hear its roar.
Mission accomplished.
Thank you
el__burro
;D
Congratulations feels good don't it? ;D ;D
Bitsa
Well done el burro, it feels good when things go well
pete
Makes it all worth while :), don't worry about the mechanical noise, a lot of that will go once the carbs are balanced and the engine is set up properly.
