General => New Member Introductions => Topic started by: Greebo on February 17, 2015, 10:36:52 AM
Hi guys,
Just to say Hi to you Honda Freaks like me.. 8)
I am just having finished a CB750 K6 completely rebuilt/restored as a café racer, it should be finished next month. when it done I will pop some pictures on here.
I also have a Triumph Thruxton & a RE 535 GT, both are great Fun... ;D
Hi and welcome, I like the Enfield!
Hi,
And welcome a great frendly forum to be part of.
Yes welcome..Nice bikes.. like the name as well that's what the scooter lads used to call us bikers when I was at school.
Ash
Hi and welcome from me as well
pete
Hi ,Good friendly site this is, British iron as well.
Cor Ash i remember the Greebo thing altho' i had forgotten it
until you hust raked over my grey matter.
Greebo's were rockers
Hi Guys
Thanks for the warm welcome, & yes I am an old Rocker from the 60's, 8) hence the nick-name. Just popped a couple more photos on of how the Honda Build was looking the other day, wont be long now , this guy who's building it is Sh*t hot with the early Honda 4 sohc ..I am getting a bit exited now, I might be growing old [ish] but i'll never grow up. 8) :o
Some of us also said greaser
Welcome
Bitsa
yes… welcome aboard!
It was "Greb" where I come from!
Welcome, looks like you will fit in to the mad world of the SOHC.
At Last All dun & dusted, I hope you guys like... :o... 8)
Nice bikes all of them, we used to be known as greasers or greebos.
Superb build that Greebo, well done. Does it run and tick over okay with the F2 carbs on it?
Looks fantastic!!
Number plates: saw a Triumph Thruxton (red with the white stripe down the middle) with a black 09 plate. This is Canary Wharf car park and in London they seem to cr@p on you for revenue when you think about rolling a wheel out of place. Wretched CSO Home Guard types.
Oddjob: in my book that is a fight case. Sounds like vigilanti-ism as well >:( what's wrong with people??
Hi Roy,
Sorry for the late reply, but I had not got the bike on the road at that point, now I have, & No it did not run properly, it did tick lover OK, but it was lacking fuel, so re-jetted it with 135mains & lifted the needles 2 notches, but it was still missing especially on the 3rd cylinder....back to the workshop, stripped the carbs again & fitted new bowl kit to all 4 carbs , it is now runs spot on...
Question
The only other issue I have is with the clutch, it is a new clutch, but it only pulls away when the leaver is right at the end [as though its ready for a new clutch] we have tried adjusting on the cable & with the plate off on the internal adjuster. have you or Anyone alse got any ideas ?
Sounds a bit like the lifter mechanism isn't lifting fully. Its a system where ball bearings run up a ramp as the cable turns the lifter. I would check that as a start point.
Update
After a few teething problems [which are to be expected] the bike is now fully sorted & running like a dream,the performance is much more than I expected...... ;D.. 8)
I like that, good job.
Tell us what cured your clutch, others might have the same problem
With the clutch we simply tried different adjustments until we sorted it, a combination of internal & external tinkering.
With the carb setting issues we first had, we fitted 135 jets & lifted the needles 2 notches from the stock setting, but it was still lacking fuel, so we tried one more notch on the needles & Bingo,it now goes pulls like a train.. 8) could not be happier, but it has took sometime to get here, we started this project last year... :o
