Other Stuff => Misc / Open => Topic started by: Green1 on March 06, 2015, 10:42:28 PM
Title: Brake calliper piston removal
Post by: Green1 on March 06, 2015, 10:42:28 PM
When using an airline to remove the brake calliper piston how much pressure do you use mine wouldn't budge until I got to about 20psi it went with a hell of a bang it shot up about 10feet before it came back down and clouted me on the shoulder. ::)
Mick
Title: Re: Brake calliper piston removal
Post by: mike the bike on March 06, 2015, 10:45:10 PM
It's always best to use hydraulic pressure for that reason.
Post by: Green1 on March 06, 2015, 10:49:57 PM
I did think about fitting it to the bike but laziness got the better of me.
I won't be doing that again.  ;)
Mick
Post by: Bryanj on March 06, 2015, 10:50:48 PM
The first mistake most people make is disconnecting the caliper DON'T DO IT put the ccaliper ina tin or bucket still connected and usr the master cyl to pump the piston out
Post by: Green1 on March 06, 2015, 10:53:23 PM
The calliper was already of the bike and sitting on the shelf for years so I'm not guilty of that.
Mick
Post by: Johnwebley on March 07, 2015, 07:22:44 AM
my friendly local motorbike engineer has modded a pipe with a schrader valve and he connects to his airline ,
he helped me a couple of years ago,we wrapped the caliper in cloth,and used gloves ,the piston was stuck,and with penetrating oil
we got it to move a little,pushing it back in until it moved enough to come out,
just popped into my hand with no real force,
needless to say ,a good clean and new seal did wonders,
Post by: haynes66 on March 07, 2015, 09:12:58 AM
as already said, wrap it up in something first. mate of mine lost the use of his eye by using air.
Post by: martin_uk on March 07, 2015, 10:35:47 AM
Also a good idea to use a piece of wood to limit piston travel, so it doesnt shoot out.
Post by: Bodd on March 07, 2015, 02:39:29 PM
I use a wellington boot with a rag at the bottom, grip the top of the welly holding the caliper inside with the piston aimed at the bottom of the boot and give it a blast of compressed air, goes with a bang but no damage to piston or anything else.
Post by: petersy on March 07, 2015, 04:24:06 PM
Just did my CB550 like that. Replaced the master cyclinder first - filled with hydraulic fluid - took the caliper off and just pumped the brake lever - the piston and disc came out a treat.
Post by: Bitsa (Ralph Wright - RIP) on March 07, 2015, 08:07:08 PM
Peter
Too small for me but lovely looking 350/4
Bitsa
Post by: LesterPiglet on March 08, 2015, 12:23:53 AM
Even better is a grease gun to pop it out. A bit messy but no fear of any damage.
