Other Stuff => Tricks & Tips => Topic started by: Bryanj on May 10, 2015, 01:16:37 AM
Title: Engine earthing point
Post by: Bryanj on May 10, 2015, 01:16:37 AM
Having found a NOS engine mount out for Julie i thought it would be a good idea to post a couple of pics on the board.
If you look closely at the large hole you will see on either side that there is no paint. This is to allow the metal of the engine and the ring terminal of the earth lead to make good contact with the bracket so you have a good earth point
So all you peeps who have your frame and everything painted/powdercoated take note and remove aforesaid coating in this area, also up where the coils mount and the small green lead fits
Title: Re: Engine earthing point
Post by: Tiny Tim on May 10, 2015, 08:09:40 AM
Thanks for pointing that out, it is something I would have certainly missed.
