SOHC.co.uk Forums => CB500/550 => Topic started by: corromant on July 07, 2015, 03:35:45 PM
Title: Ignition keys
Post by: corromant on July 07, 2015, 03:35:45 PM
Does anyone know if period keys can be obtained & where from. It would be nice to have a spare.
Conrad
Title: Re: Ignition keys
Post by: Trigger on July 07, 2015, 03:53:00 PM
The original key is a T key and if you have the number they can be found in the states. If you just want a non original key, many places will cut by the number.
Post by: corromant on July 07, 2015, 03:56:16 PM
Thanks Trigger will have a bit of a google
Post by: Trigger on July 07, 2015, 04:01:53 PM
For non original keys I have used this guy many times >>http://www.ebay.co.uk/itm/HONDA-MOTORCYCLE-KEYS-CUT-TO-YOUR-CODE-NON-TRANSPONDER-TYPES-PLEASE-ENQUIRE-/281030401159?pt=LH_DefaultDomain_3&hash=item416eb79c87
Post by: Chris400F on July 10, 2015, 11:33:59 AM
Just received a spare key for my 400/4 which I ordered having seen Trigger's post.
Just the job, works perfectly.
As the guy says in the listing, better to cut to code than to copy a worn or damaged key.
Just wish I could get a steering lock key now, but even the information that came with the bike from new only has the ignition key code.
Post by: corromant on July 10, 2015, 11:58:10 AM
Mine have arrived this morning, spot on. Very helpful guy, had to send a photo of one of the keys before he confirmed he could cut it. Both keys work fine.
Thanks Trigger
Post by: tom400f on July 10, 2015, 12:23:48 PM
I'm not sure these are available. You have to get a new lock and drill out the old one. Simple enough to do though: http://www.sohc.co.uk/index.php/topic,4947.0.html
Post by: Chris400F on July 10, 2015, 01:10:30 PM
Thanks Tom, that doesn't look too tricky.
Guess I should probably start by ordering a new lock then!
Post by: Bryanj on July 10, 2015, 06:00:37 PM
You can't buy keys for Neiman locks you have to drill it out after carefully removing the rivet and washer for reuse. Dont go berserk with the drill there is a spring on the end of the lock that comes seperate
Post by: Trigger on July 10, 2015, 06:23:57 PM
Steering locks can be cheap from Frank>>> http://www.ebay.co.uk/itm/HONDA-CB-250-350-400-450-500-550-750-Four-Lenkschlos-Lenkradschlos-steering-lock-/131543167059
Post by: Chris400F on July 10, 2015, 07:47:48 PM
They are, but he doesn't do PayPal and I've never heard of the options he does take (IBAN or BIC).
Maybe that's because I'm not a seasoned overseas buyer!
I have ordered from here:
http://www.ebay.co.uk/itm/Handlebar-Lock-Lenkschlos-Steering-Lock-Steering-Lock-For-Honda-Kawasaki-/231388905798?pt=LH_DefaultDomain_3&hash=item35dfda8146
A bit more than Frank but still much cheaper than DS and the like.
Post by: Trigger on July 10, 2015, 08:42:46 PM
Frank does Paypal !
Post by: Chris400F on July 11, 2015, 10:12:02 AM
I have looked at the listing again and you're right, he does. He just says it is not his preferred method of payment due to charges.
It seemed strange, I thought if you deal on eBay then PayPal is pretty much obligatory, as a seller you factor charges in to your prices.
Still suspect many people will have no idea what IBAN and BIC are though.
You live and learn!
Post by: royhall on July 11, 2015, 10:21:22 AM
An IBAN is an International Bank Account Number. You have to bank transfer directly to that account. Bit risky online if you ask me. No protection whatsoever.
Post by: Chris400F on July 11, 2015, 10:32:29 AM
PayPal sounds the way to go then.
Sellers who make the buying process more difficult don't get my custom I'm afraid.
Post by: royhall on July 11, 2015, 10:45:34 AM
+1 on that Chris.
Post by: tom400f on July 11, 2015, 05:36:06 PM
That's better than when I got one. Mine came with the L shaped keys as in the picture.
Post by: royhall on July 11, 2015, 06:07:08 PM
Where do you find the ignition key numbers on the 750F2. Thanks.
Post by: Trigger on July 11, 2015, 06:36:07 PM
Try looking for the number on the lock's
Post by: tom400f on July 12, 2015, 09:04:10 AM
I think it's as simple as removing that cowl covering the lights and the number is on the side of the barrel.
Post by: wolfheze on July 13, 2015, 01:05:46 PM
Had a new genuine Honda key arrive today from Mark at Hondakeys.com. in Pensylvania. great service.
Post by: Chris400F on July 20, 2015, 05:02:13 PM
New lock arrived today. One week from Germany, not sure if that is good or bad but it got here.
Out with the B&D to drill the old lock, fitted quite easily so all sorted.
The eBay listing I bought from offered 'A guide with photo' on request, so I requested - a bit more guidance couldn't go amiss.
Not sure that it added much, and I don't think I would recommend risking using one of the new keys to help remove the old lock!
So this is what you do ....
Post by: Trigger on July 20, 2015, 09:24:18 PM
You could of got one from DSS in 4 day's at twice the price  :D :D :D :D
