SOHC.co.uk Forums => CB500/550 => Topic started by: shifter on October 21, 2015, 06:14:12 PM
Title: 550f1 engine removal
Post by: shifter on October 21, 2015, 06:14:12 PM
Hi Guy's , can anyone tell me , is it possible to remove a 550 engine from the frame without removing the sump , I understand  removing breather cover would be necessary, also is it easier to lift out from left or right
Title: Re: 550f1 engine removal
Post by: shifter on October 21, 2015, 06:30:45 PM
Many thanks odd job, I didn't really wanted to disturb sump, but it sounds I have to , eh  cheers,
Post by: JustcallmeMrT on October 21, 2015, 07:00:37 PM
I've had success removing the oil filter, breather cover and points cover, then  lay the engine on the right side on a nice soft surface (pillow) and lift the frame off of it.  Saves removing the sump, but not easy if the bike is fully assembled.
Post by: matthewmosse on October 21, 2015, 09:40:32 PM
I always just pull the oil filter and breather cover, but then I am not the sort to worry about the paint and genrally have wanted the engine swapped inside a weekend. Also I wouldn't want to risk scoring the sump gaskett face when juggling an engine in a fully built up bike with no helpers around.
Post by: Nurse Julie on October 22, 2015, 08:43:55 AM
I managed to remove the engine on my 550 with the sump still attached, I just removed the oil filter housing and breather cover and it came out on it's side no problem. Also, as I'm standing here looking at the sump, I wouldn't sit the engine on the floor without the sump on as there is a little oil tube thingy, that looks like that would hit the deck and snap off. I will say, I did have to have help to actually lift the engine from the floor once out of the frame  ;D ;D ;D ;D
Post by: Norniron on October 22, 2015, 07:43:23 PM
Hes useful for some things then julie 😉😉
Post by: Nurse Julie on October 22, 2015, 08:20:28 PM
 ;D ;D ;D ;D ;D Yes Dave, humping engines around is definitely his speciality
Post by: matthewmosse on October 22, 2015, 08:38:55 PM
The engines sit nicely enough with the oil filter housing and sump in situ, and as my shed is a bit of a mess I normally stick the oil filter back on as soon as that bit is clear of the frame, but still supported, minimalising the chances for dirt or dust to get in. I have about 8 500/550 engines stood like this awaiting either work or installation. I also like a very basic engine stand I picked up in a job lot that allows me to test engines complete with exhaust without installing it.
Post by: bomber on October 22, 2015, 08:47:28 PM
Matthew, any chances to see a picture of that engine stand?
Post by: shifter on October 23, 2015, 07:15:49 PM
Hi Guys, thanks for all your response and advice , yes it's out, managed  to keep sump on just removed top cover and oil filter, also a little wriggling, Happy Days.
Post by: matthewmosse on October 25, 2015, 01:43:55 PM
I will try to get away from kids long enough to dig it out if possible, fraid shed time is set to be very limmited til the little horrors ( kids) start school, and that is a very long 2 years away  :'(
