SOHC.co.uk Forums => CB750 => Topic started by: AshimotoK0 on February 17, 2016, 09:43:25 PM
Title: Pic for Trigger showing funny ring that goes under three piece oil ring on K0
Post by: AshimotoK0 on February 17, 2016, 09:43:25 PM
Here goes Graham on K0 funny oil control ring under main oil ring. Hondaman told me to discard the funny ring.
[attachimg=1]
Title: Re: Pic for Trigger showing funny ring that goes under three piece oil ring on K0
Post by: AshimotoK0 on February 17, 2016, 10:43:41 PM
Can't see it myself Ash, all I can see is the old style oil control ring which was cast in one piece before they started to use the 3 separate part oil rings.
No3 looks odd though, can't seem to place where or what that is.
You can see it here Ken
 [attachimg=1]
Post by: Trigger on February 17, 2016, 10:55:49 PM
See what you mean now ;D
Post by: Bryanj on February 18, 2016, 07:22:45 AM
Used a lot on older car style, Its there to help push the oil ring out to the cylinder wall which the centre bit on the 3 piece does as well but the thin side bits scrape the oil better than the big thick ring.
That No3 is the little rubber bung between the fins
Post by: MrDavo on February 18, 2016, 10:54:06 AM
Don't start me wanting a set of those again. I thought I was over it.
Post by: AshimotoK0 on February 18, 2016, 12:14:50 PM
If you buy a Noboru Packing full gasket set the rubber bungs come with it!
Post by: K2-K6 on February 18, 2016, 06:42:15 PM
The top rings always get help to push against the bore by the compression, more of a challenge for rings further down as they're trying to scrape all the oil they can while not raising friction too much.
Post by: gtmdriver on February 26, 2016, 09:17:22 PM
It's called an expander ring.
