SOHC.co.uk Forums => CB750 => Topic started by: Phil Ward (RIP) on March 06, 2016, 08:26:59 PM
Just re-furbing front caliper that I bought from DK and the brake pad 'puck' - part number 45151300000 is missing.
Is it required? I have one on my other K2 but unsure what K model this is off and if they where fitted to all models. The caliper came with pads so I assume the bike it came off was being used without it.
If you mean the hylon washer they regularly used to go missing and wernt used with pattern pads anyway
The one on my K2 is steel - but if pattern pads don't use them, that's probably why its missing from the caliper I'm re-building - as long as its ok without, that ok with me!
Thanks Brian
Now the piston has a big steel blanking washer over the centre hole and then there was a nylon washer between that and the pad. I have fitted wing pistons(all i could get at the time) which have no steel washer and they worked OK
Big insert on my 750K0 was also domed slightly too Bryan (convex)
That's the same as the one on my K2 as well
Sent from my XT1032 using Tapatalk
