SOHC.co.uk Forums => CB500/550 => Topic started by: bike addict on April 06, 2016, 05:31:08 PM
Hi. Would anyone have any advice for what groove the standard needle jet setting is please for my CB500/4 K0? It runs all all original carbs, pipes, air box and filter. My original Honda owners manual and all the other references I have seem to omit this detail. Your help much appreciated. Many thanks.
Martin
South Coast Sussex
As a rule, Honda set them to the middle notch.
Sent from my D2303 using Tapatalk
I recently re-built my 500k2 carbs,
I think they were still original settings,all 4 needles were 1 slot above the bottom slot,
Standard is middle groove
Standard is 3rd (middle) position. An American Honda Motor Company spec. booklet (1977!) is the only source that recommends 4th. On the same page it recommends to have the airscrews 2 turns out instead of the 1 +/- 1/8 documented everywhere else. If that information is true, my guess is that US was interested in a less polluting idle and compensated this by bringing the needle a bit higher. FWIW.
Many thanks for all your input - it's much appreciated. I'll go with the middle (third) groove to begin with and then go from there.
...my guess is that US was interested in a less polluting idle and compensated this by bringing the needle a bit higher. FWIW.
Still are...
Even the ST1100 has smaller main and idle jets over there...
