Author Topic: Idle Mixture Setting  (Read 4996 times)
Offline Honda Al
« on: April 28, 2016, 06:30:40 PM »
Hi all,
Forgive me if this has been covered elsewhere, but what is the adjustment setting for a CB500 K1?
I've read two pieces of information -
1. 1 turn + 1/8
2. 1 1/2 to 2 turns.
Anybody found one better than the other?
Thanks, Alan
Offline ST1100
Re: Idle Mixture Setting
« Reply #1 on: April 28, 2016, 06:50:28 PM »
Original air-filter/box?
Which jet size?
STOC #637
Offline Honda Al
« Reply #2 on: April 28, 2016, 07:01:15 PM »
Which jet size?
Original air filter and box. Not sure about the jet size - assuming standard?? I've not changed it.
« Reply #3 on: April 28, 2016, 09:15:39 PM »
What source says 1 1/2 to 2 turns?
1 turn +/- 1/8 is official but for some reason the yanks have different.
« Last Edit: April 28, 2016, 09:19:33 PM by deltarider »
« Reply #4 on: April 28, 2016, 10:09:55 PM »
Hi all,
1. 1 turn + 1/8
Thanks, Alan
 pilot jet   40
main jet    100
 airscrew   1  plus/minus 1/8
BUT after a Cruzimage rebuild kit,seems to be better at 1 1/4 airscrew,suggest you start at 1 turn,then adjust by 1/8 and see
how it goes
Offline Honda Al
« Reply #5 on: April 28, 2016, 10:11:36 PM »
Clymer manual.
« Reply #6 on: April 29, 2016, 07:22:01 AM »
Clymer manual.
Although there's a Clymer on the shelf, I never consult it. If you refer to page 109, it could well be a CB550 carb is in that picture.
When I set my CB500 like Clymer says, it will pick up poorly and runs hotter the last kms in the city when I return from a ride. Mine is happy around 1 turn out.
You may read: http://www.sohc.co.uk/index.php/topic,9915.msg70445.html#msg70445
« Last Edit: April 29, 2016, 07:24:36 AM by deltarider »
