Author Topic: Low oil pressure at high temps?  (Read 5110 times)
Offline JustcallmeMrT
« on: May 06, 2016, 06:13:21 AM »
Hi all,
I've finally passed my mod 2 and have been taking my bike (1977 CB550F2) to work and back for the last 2 days.  Mornings all is fine, but in afternoon traffic the oil pressure light comes on as the bike starts to get hot.  It has sufficient oil, and I popped the tappet inspection caps and all seems oily up top, so not sure what's going on.  Any suggestions?
Sent from my SM-N9005 using Tapatalk
Re: Low oil pressure at high temps?
« Reply #1 on: May 06, 2016, 06:30:25 AM »
Does the light go out again above tickover/idle speed? If so, it is not unusual on a high mileage engine, also if it has new rings and shells it will run hot until properly run in. If the oil light comes on much above idle, STOP the engine and investigate further. Well done on getting your licence.
« Reply #2 on: May 06, 2016, 07:18:17 AM »
Hairy is on the right line here. Because you are running new rings, the engine will be running hotter than normal. But, sitting in traffic is not a good way to run a top end in. Have had this problem with 500's and 550's, it was the oil pressure switch.
Have you done a oil pressure test ?
Keep an eye on it
« Reply #3 on: May 06, 2016, 10:34:20 AM »
Thanks Hairy.  The light doesn't go out above idle, bit does go out after the bike cools a bit.
« Reply #4 on: May 06, 2016, 10:34:43 AM »
Keep an eye on it
How do I check oil pressure?
« Reply #5 on: May 06, 2016, 02:12:39 PM »
Easiest test is substitute the switch which is on the oil pump, or you can put an adaptor in there to actually check the pressure, but you cant put the cover back on with a pipe connected instead of the switch. Don't put a car switch in there as they work at a different pressure
« Reply #6 on: May 06, 2016, 02:16:10 PM »
Any suggestions for where to get a switch?  Is it a generic unit or do I need a Honda part?
Offline TonUp
« Reply #7 on: May 06, 2016, 06:57:21 PM »
I had the same problem with my CB550F2, got a new oil pressure sensor from David Silver. Fixed the problem. It was about £20 I think.
Honda CB550f2 1977
Offline flatfour
« Reply #8 on: May 06, 2016, 08:56:10 PM »
It might not be the correct thing to do, but as this always happened to my Benelli 750/6 when hot I talked to members of the owner's club and a recognised expert on type and was told to always use 20/50 oil as soon as winter was over. The problem has never returned and very many miles have been covered since.
I now change to 20/50 for the Honda's at around Easter each year, although I have never had the oil light illuminate on them with the engine running it certainly doesn't seem to have done any harm.
In the 1970's, all of my bikes were run on Duckhams Q20/50 throughout my ownership without any mechanical issues arising.
