CB350/400
Oil pickup question
Topic: Oil pickup question (Read 2619 times)
Mr-Gear
SOHC Associate
Oil pickup question
May 18, 2016, 09:17:46 AM »
Hello good people,
Just a quick question regarding the oil pickup in a cb400f.
What is the function of the spring that is inserted between the oil pick up and the casing? is it critical? Mine is missing for some reason.
Thanks, Ryan
Orcade-Ian
Re: Oil pickup question
May 18, 2016, 12:43:39 PM »
If you are referring to the spring which fits between the strainer cone and the lower engine case, it's there to ensure that the strainer is always in good contact with the metal plate screwed to the sump pan. This means that any large particles are trapped by the strainer and can't get between the strainer and the wide end of the cone and into the oil pump. Part number is 15157-333-000
David Silver or Steve at 400/4 parts should be able to help - same part as 350/4 too
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Chris400F
May 18, 2016, 03:50:20 PM »
Steve has a pickup complete with spring listed at the moment.
His site is at
http://www.400fourbits.co.uk/
CB350/400
Oil pickup question
