DID Chain
Topic: DID Chain (Read 6059 times)
Dave1234
Newbie
DID Chain
May 18, 2016, 07:29:53 PM »
Hi all, just brought a new DID chain and JT sprockets for the 550, question is the chain dosen't have the old u shape clip, it comes with four o rings. Is this now a compression joint? If so what do you compress it with.
Honda Al
SOHC Expert
Re: DID Chain
May 18, 2016, 07:35:12 PM »
Ideally you'll need a proper chain tool that will compress, and then 'preen' (is that the right word??) the rivets over a little to keep the link in place. Not a difficult job to do with the right tool.
My only piece of advice would be when compressing the side plate of the link on, use a vernier gauge to compare the thickness of the other links so you know when you have it just right. Then it won't be to slack or too tight. I got that little gem from another member on here.
Alan
Dave1234
Newbie
Re: DID Chain
May 18, 2016, 07:48:43 PM »
Okay cheers Alan, next question where do I find the compression tool?
So if it is compressed on and the rivets rounded over (preened) what happens when you want to take the wheel out again (say if you get a puncture) and need to take the chain off.
K2-K6
Re: DID Chain
May 18, 2016, 08:08:41 PM »
With a continuous chain you'd normally withdraw the wheel spindle and move the wheel as far forward as possible then pull the chain off the sprocket and move it sideways to the left, most bikes you can hook it onto the chain adjuster bolt to keep it out of the way while you remove and work on the wheel.
Refit is just the reverse of wheel as far into the swingarm as poss, pull the chain out and drop onto sprocket, then pull wheel back into position to put spindle in.
There's a rogue r in that "preening " as it should be peening of the rivets.
matthewmosse
Re: DID Chain
May 18, 2016, 08:22:04 PM »
I peen the rivetts with a ball peen hammer against a small ( 5kg ) anvil, but as a blacksmith that appeals to me more than yet another tool. With expirience it is possible to get it so as not to be too tight or loose. I do sometimes resort to removing the swing arm to fit the chain as a continuos one, especially if it has not been removed recently, helps double check everything is thouroughly greased and not wearing unevenly or anything untoward, and if it is then I like a good bit of notice to start hunting for spares before it becomes a problem.
Green1
Re: DID Chain
May 18, 2016, 08:44:09 PM »
Heres the tool you want
http://www.ebay.co.uk/itm/MOTORCYCLE-BIKE-CHAIN-BREAKER-SPLITTER-LINK-RIVETER-UNIVERSAL-SET-RIVETING-TOOL-/111771595907?hash=item1a061b3483:g:w20AAOSwAHZURMeN
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
totty
SOHC Expert
Re: DID Chain
May 18, 2016, 08:50:37 PM »
Before fitting check case clearance, some o ring chains are too wide and cause damage.
Krzychu
Newbie
Re: DID Chain
May 21, 2016, 09:34:29 AM »
Hi there, I bought DID chain and JT sprockets for my Nighthawk too. Now waiting for the tool that Mick has advised. I wonder if its really a Sealey tool, seems very cheap. I went and asked at my local tools shop that sells Sealey and they sell them at £40, he even told me that they pay £28 for them. Anyway, we shall see when it comes 😉
LwG
LwG✋
Green1
Re: DID Chain
May 21, 2016, 11:35:12 PM »
Its not a genuine Sealey tool but exactly the same as I have one of each as I lost a few bits from the Sealey one
They both came in exactly the same blow molded cases and are interchangable.
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
Krzychu
Newbie
Re: DID Chain
May 23, 2016, 05:20:02 PM »
That's good, as long as it does the job I'll be happy with it 😃
LwG
LwG✋
DID Chain
