Author Topic: Keihin PD carbs Accelerator Pump Cover / Help Needed  (Read 3720 times)
Greebo
« on: May 27, 2016, 10:53:09 AM »
Hi Guys
Help Needed
Does anyone know where I can get the bottom plate to the accelerator pump PD carbs, & possibly the plate itself ? within the UK preferably, or if anyone has the spares I am happy to pay the going rate
I noticed a slight leak at the bottom of the accelerator pump, the screws would not tighten any further [screw heads are a bit knackered now with trying] & the leak continues
I have been advised that the pump diaphragm is knackered, so I am going to fit a new complete one, but need the bottom plate if possible
PS..
I have got new the diaphragm kit
if anyone can help I could do with the "bottom plate" shown below
Greebo
« Last Edit: May 28, 2016, 07:52:21 AM by Greebo »
Re: Accelerator pump cover & screws Keihin PD carbs /Help Needed
« Reply #1 on: May 27, 2016, 12:23:19 PM »
May have one ... will look.. screws should be pretty common .. may have new ones but not JIS style.
Greebo
« Reply #2 on: May 27, 2016, 12:38:23 PM »
Hi
what do you mean by JIS style
my carb numbers are: PD41A[A] PCI....if this helps
« Reply #3 on: May 27, 2016, 01:23:10 PM »
Only place I could find for those was CMS. The plate has a valve in the bottom of it that is prone to gumming up. Their not cheap items new.
Greebo
« Reply #4 on: May 27, 2016, 02:43:24 PM »
Tried calling CMS but they don't answer, I would rather try & get one over hear in the UK if possible, I am not sure that the bottom plate is absolutely needed but if I can find one then I will have it...but I do need the Screws & Washers
any other offers guys
« Last Edit: May 27, 2016, 06:12:22 PM by royhall »
Greebo
Keihin PD carbs Accelerator pump cover
« Reply #6 on: May 27, 2016, 07:28:38 PM »
Hi Roy
Thanks for the links
But I have already got the new accelerator pump Diaphragm unit.. but no bottom securing plate, what I want is the bottom plate, screws & washers & they don't have to be new, if anyone has got any of these bits Especially the bottom plate & does not want them I will buy them.
I will perhaps get the screws locally from a nut and bolt supplier they are only pan-head M4 x 12mm & 4mm washers
image of bottom plate I need shown below
cheers
greebo
« Last Edit: May 28, 2016, 07:48:05 AM by Greebo »
« Reply #7 on: May 27, 2016, 09:46:36 PM »
I have searched and can't find one sorry. Pretty sure I had one,  I can picture it but not found it   :-[ :-[ and I suspect you need it sooner than later.
