Author Topic: Out of ideas and need help!  (Read 3170 times)
Offline Honda Al
« on: May 29, 2016, 05:14:05 PM »
Hi all,
Today I thought I would replace a leaky cylinder head gasket. All going well, stripped down ok (apart from an odd curse word!) and I cleaned up the area and replaced the gasket. Replaced the everything in the reverse order, following the instructions, and when I went to re-adjust the valves the engine wouldn't turn over by the kick starter. Just stopped dead.
I removed the cylinder head cover and everything turns over again. What am I missing? Without the cover turns over, with and it stops dead.
Alan
Offline JustcallmeMrT
Re: Out of ideas and need help!
« Reply #1 on: May 29, 2016, 05:38:59 PM »
Might be a stupid question, but are all the tappets sitting aligned correctly on top of the valves?  If they're skewed, could jam it up?
Sent from my SM-N9005 using Tapatalk
« Reply #2 on: May 29, 2016, 06:07:05 PM »
check the cam timing,
 if you keep the rocker cover off,does it,and the cam turn over?
when you re-assemble the rocker cover,use 4 elastic bands to hold the rockers up,
try this
Offline Honda Al
« Reply #3 on: May 29, 2016, 06:25:40 PM »
try this
Cam turns over nicely with rocker cover off, but not when I put it on and screw it down. I thought I had the timing done, but it did throw me slightly because there were two markings on the cam lobe - pointy arrow/triangle and a square section.
Nice tip about the elastic bands, I'll try that.  :D
« Reply #4 on: May 29, 2016, 07:11:00 PM »
when cylinders 1-and 4 are at TDC,the slot in the end of the cam,should be at the 3pm position
parallel to the joint line,MOST important
Offline Honda Al
« Reply #5 on: May 30, 2016, 10:55:27 AM »
All fixed and running perfectly. Thanks guys.   :)
The odd thing was I had two markings at the end of the cam shaft - squared out notch and an arrow point notch pointing towards the edge.
