Author Topic: Master Cylinder Holes  (Read 2441 times)
Offline petermigreen
« on: June 08, 2016, 10:13:59 PM »
Currently overhauling the front brake master cylinder, when I look in the pot, there are two holes, one is full bore and the other one seems much smaller, very small in fact, so much so that I can't tell if it's blocked.
Before I force something through it, can someone confirm that both holes should be clear/open. I'm fairly certain they should be as I seem to think the smaller one is to allow the piston to return, but don't want to force something through it if not.
Thanks, Peter.
Re: Master Cylinder Holes
« Reply #1 on: June 08, 2016, 10:37:17 PM »
Yes, they should both be clear, the smaller one is return/bypass hole, if that gets blocked it causes problems releasing the caliper piston, causing dragging/binding.
« Reply #2 on: June 08, 2016, 10:38:58 PM »
Cool, thought so, just wanted to make sure.
Thanks, Peter
