Author Topic: Wheels mis-aligned!  (Read 3354 times)
Offline ginger_jim
  • Anyone for a Guinness?
Wheels mis-aligned!
« on: June 12, 2016, 04:07:23 PM »
Hi all, took the K7 for MOT yesterday and it sailed through except we couldn't get the wheels aligned (got soaked to the skin in to the bargain >:()  Tester was using two straight lengths of ally. We had to adjust the rear wheel miles out on the chain adjusters.  Hopefully you can see from the photos that the chain side is adjusted out about 5mm more than the brake side. As far as the tester was concerned it wasn't a failure as long as the wheels were aligned so the bike passed.
When I rebuilt the bike the right, front brake lever side, fork leg was found to have a small bend in it.  My question is, if the bottom yoke is twisted due to the same impact would it kick the front end out that much?
Cheers, Jamie
Offline Green1
Re: Wheels mis-aligned!
« Reply #1 on: June 12, 2016, 04:27:12 PM »
I have known the marks to be out on an ER5 from new and my CG125 is the same.
I would be very surprised if the yoke is twisted as they normally crack rather then bend more likely the swingarm is bent.
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #2 on: June 12, 2016, 05:20:42 PM »
Ignore the marks as Honda tell you to because then are only a guide for chain adjustment, as long as the wheels are it line and vertical thats all you need
« Reply #3 on: June 12, 2016, 05:22:39 PM »
I'm no expert but after putting the back wheel in my 400/4 after I changed the swinging arm bushes, I put the rear wheel spacers in the wrong way round, ie, the left on the right and vice versa. The bushes are slightly different lengths on the 400 but I don't know about on your bike. I only knew about it when riding at quite high speed and got the wobbles at the back end. The wheels were definitely not aligned.
Offline MarkCR750
« Reply #4 on: June 12, 2016, 05:28:34 PM »
Riding at high speed always gives me the wobbles at the back end as well Julie 😀
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
« Reply #5 on: June 12, 2016, 05:30:51 PM »
Having met you Mark, I can understand that 😃😃😃
Offline MarkCR750
« Reply #6 on: June 12, 2016, 05:39:05 PM »
Ha, btw you were on a 400/4 at high speed?, did you go over a cliff? 😄
Back to the subject, agree with above, no problem with your bike, but go to the same MOT guy next time, if you get another one that thinks your frames bent you'll be in a world of pain, I had one say my ZXR had a "slightly bent frame ", he put it on as an advisory the idiot, I had to get a letter from another MOT guy stating the frame was fine (which it was) or I'd have never been able to sell it!, slightly bent!, same as slightly pregnant?.
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
« Reply #7 on: June 12, 2016, 05:42:51 PM »
Trust me Mark, it was fast for a 400/4  ;D ;D
Offline ginger_jim
« Reply #8 on: June 12, 2016, 05:59:32 PM »
Think its time to arm myself with a couple of nice straight edges as mentioned for alignment purposes.  Ive always used the marks which would explain a lot as when you wheeled the bike backwards the chain used to snag ever so slightly on the rear sprocket.  I didnt think there was too much wrong as the bike handles reasonably well, although the front end has a rather alarming knack of reminding you its a 40 year old bike if you get too friendly with the throttle.
Anyway, thanks all....you learn something new every day!  Now all ive got to do is get my kit dry for the early morning commute!  Yesterday the rain was running off my jeans and straight down my boots.....nice.
Bike didnt miss a beat though which isnt bad as the roads were more like rivers on the way home from the mot station.  My K7 back in the late 80's used to stop if you squirted a water pistol at it.....ah the innocence of youth!
Offline MarkCR750
« Reply #9 on: June 12, 2016, 06:30:04 PM »
I have to say I was quite envious when I saw it , exactly the same as the one I had in 1980, a mere 36 years ago 😳
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
