Author Topic: RIGHT HANDLEBAR SWITCH  (Read 2081 times)
watty51
« on: June 13, 2016, 08:36:23 PM »
Looking for a right handlebar switch for a USA cb350f. Checked DS but they have none........but stock one for a cb400f. As far as I can see the only difference is the lettering on the switch reads, on the 350.... RED DOT then L then H. The 400f.... reads RED DOT then P then H. What's the difference between the L and the P.
Has anyone used the reproduction ones before, if so would you recommend.
Re: RIGHT HANDLEBAR SWITCH
« Reply #1 on: June 13, 2016, 08:45:30 PM »
The 400/4 switch is off, sidelight (P) and headlight (L) . There is a separate dipswitch on the left hand switchgear.
