Author Topic: Honda CB550k3 Bearing Shells  (Read 3358 times)
Offline dawmallard
« on: June 21, 2016, 09:34:05 AM »
Hi
I am looking for brown coded crank bearing shells. I need 6 halves altogether. DS sell the green but not brown, CMSNL sell brown but at a high postage charge.
Is there anywhere local (UK) that have them?
Many thanks for taking the time to read this.
David
Proud to be an old fashioned postie
Bikes - Honda 550K3
           BMW R100RT 1996
Offline masonmart
Re: Honda CB550k3 Bearing Shells
« Reply #1 on: June 23, 2016, 07:21:19 PM »
dm, I looked hard and long for the right bearing shells and in the end I bought 10 of what I could get and checked them against the actual measured journal diameters and the crankcase code and they were OK. I put them in, tightened them up and the engine tuns fine with no detectable play. The advice I was given was that it just isn't critical. You just can't get the exact ones that you need anyway.
I'll run mine in carefully with running in oil and whilst theoretically they may be tight I don't believe they are and running in will do what it says on the can.
Dresda CB500-4, 605 cc
CB-77, 350 cc
1968 Bonneville
1976 Thruxton Velocette
1974 Kawasaki Avenger
1997 VFR 750
« Reply #2 on: June 23, 2016, 07:26:08 PM »
Go for Black with a little graphogen and everything should be fine.
Offline dawmallard
« Reply #3 on: June 23, 2016, 08:49:53 PM »
Could I just get more green to go with the new ones that I got from DS or bite the bullet on the postal charge and get the brown ones from cmsnl?
Are the green ones a tighter or looser fit?
Black shells seem very hard to track down.
Got the graphogen to hand.
Bikes - Honda 550K3
           BMW R100RT 1996
« Reply #4 on: June 23, 2016, 09:11:06 PM »
green are looser and black has less clearance than brown.
