Author Topic: Cam Cover Sealing Washers  (Read 3271 times)
Offline Seabeowner
« on: June 22, 2016, 11:21:22 AM »
I have bought two different manufacturer top end gasket sets for my two 550s and both are missing the 6off "lozenge" rubber sealing washers that cover the access to the head nuts. Is this normal as they include the large wavy O ring for the cover itself? It is annoying as the they seem to be over £3 each, unless somebody knows otherwise.
Should they always be replaced?
I have some from a set from a 500 that I did a dozen years ago and I'm sure they were included. At least I'm OK for one bike.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline JustcallmeMrT
Re: Cam Cover Sealing Washers
« Reply #1 on: June 22, 2016, 12:13:41 PM »
I also had to buy them separately - I was told they used to be part of the Vesrah gasket sets,  but aren't any longer.  I think I ordered them for £12 for the set off eBay.
Sent from my SM-N9005 using Tapatalk
Offline Seabeowner
« Reply #2 on: June 22, 2016, 12:53:49 PM »
Thanks for that.
And strangely both sets include the 8off 10x1.6mm O rings that go under the valve guides. I've never replaced them. Should I?
Offline matthewmosse
« Reply #3 on: June 22, 2016, 09:02:30 PM »
Maybe I am lucky but I always re use them 6 lozenge bits and as yet have not had one leak from about 4 or 5 engines and a few more top end rebuilds.
« Reply #4 on: June 22, 2016, 10:06:22 PM »
Thanks for that.
Mine came with those too - I figured I wasn't going to have the guides pressed out just so I could replace a seal so didn't use them.
